allred
#1 Posted : Tuesday, December 16, 2008 6:46:50 AM(UTC)
allred
:confused: My GE dryer heats great but when drying clothes has an annoying loud sqeaking noise. The wetter the clothes or heavier the load the louder the sqeaking. What should I replace to fix my problem? Could it be the felt or bearings? What is the felt for anyway? How can I purchase a manual?
#2 Posted : Tuesday, December 16, 2008 8:25:34 PM(UTC)
Open the door and remove the screw on each side of the door frame, holding the top panel. Lift the top panel up and remove the screw on each side of the front panel. Remove the wires to the door switch and remove the front panel.
Check the front bearing (#313 on the break down diagram) and the slides (#316 on the break down diagram).
It is a good time to clean the dryer.
Here are the break down diagrams for the GE dryer Model DBXR453EV0WW
kayakcrzy
#3 Posted : Thursday, December 18, 2008 5:00:28 AM(UTC)
kayakcrzy
It could also be the rear bearing. They also have a wonderful history of needing to be replaced. Tom ApplianceEducator.com
run with sqeaking noise (Washer Repair)
by 5957rdr 11/29/2010 9:36:45 PM(UTC)
help with sqeaking dryer (Dryer Repair)
by used stuff user 7/28/2010 7:11:59 AM(UTC)
dryer sqeaking (Dryer Repair)
by greif 7/25/2010 5:16:49 PM(UTC)
Loud Sqeaking but still works (Dryer Repair)
by rcattley 3/18/2010 6:47:17 PM(UTC)
Maytag Dryer sqeaking at start (Dryer Repair)
by xxxbowl300 12/17/2008 1:53:16 PM(UTC)
dryer making load sqeaking sound (Dryer Repair)
by SPDYFM 1/7/2008 9:00:12 AM(UTC)
