Discuss
control panel frozen
 in
Dryer Repair
I have a maytag neptune dryer model MDG6800AWW,the last time I went to use it the control panel would stay
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » control panel frozen
  #1 (permalink)
Old 02-17-2011, 06:26 PM
Junior Member
Scott Mylor is on a distinguished road
Default control panel frozen
Model Number: MDG6800AWW   Brand: Maytag   Age: 5 - 10 years
I have a maytag neptune dryer model MDG6800AWW,the last time I went to use it the control panel would stay in one position.I can not change the cycles,dry level or the temperature,if I hit the off button it will not turn off and it will not start. I unplug it for a few hours would not reset,I am wondering if my control panel is bad or if it's my board?
Related Models
Maytag MDG6800AWW DRYER- GAS
Maytag MDG7057AWQ DRYER- GAS
Maytag MDG7057AWW DRYER- GAS
Maytag MDG7057BWQ DRYER- GAS
Maytag MDG7057BWW DRYER- GAS
Maytag MDG7400AWQ DRYER- GAS
Maytag MDG7400AWW DRYER- GAS
Maytag MDG7460AWQ DRYER- GAS
Maytag MDG7460AWW DRYER- GAS
Maytag MDG7500AWQ DRYER- GAS
Maytag MDG7500AWW DRYER- GAS
Maytag MDG75MNAWW MANUAL, PARTS (DRYER GAS)
Maytag MDG75MNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75MNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PN1AW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PN2VW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNAVW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNHWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNHWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7600AWQ DRYER- GAS
Maytag MDG7600AWW DRYER- GAS
Maytag MDG7657AWQ DRYER- GAS
Maytag MDG7657AWW DRYER- GAS
Maytag MDG7657BWQ DRYER- GAS
Maytag MDG7657BWW DRYER- GAS
Maytag MDG7658AWQ DRYER- GAS
Maytag MDG7658AWW DRYER- GAS
Maytag MDG7658BWQ DRYER- GAS
Maytag MDG7658BWW DRYER- GAS
Maytag MDG76PCBWS MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG76PCBWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7757AWQ DRYER- GAS
Maytag MDG7757AWW DRYER- GAS
Maytag MDG7758AWQ DRYER- GAS
Maytag MDG7758AWW DRYER- GAS
Maytag MDG77PNAWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG77PNSWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG8000AWQ DRYER- GAS
Maytag MDG8000AWW DRYER- GAS
Maytag MDG8000BWQ DRYER- GAS
Maytag MDG8000BWW DRYER- GAS
Maytag MDG8057AWQ DRYER- GAS
Maytag MDG8057AWW DRYER- GAS
Maytag MDG8057BWQ DRYER- GAS
Maytag MDG8057BWW DRYER- GAS
Maytag MDG8058BWQ DRYER- GAS
Maytag MDG8058BWW DRYER- GAS
Maytag MDG8400AWQ DRYER- GAS
Maytag MDG8400AWW DRYER- GAS
Maytag MDG8416AWA DRYER- GAS
Maytag MDG8416AWW DRYER- GAS
Admiral MDG8426AAW DRYER- GAS
Admiral MDG8426AEW DRYER- GAS
Admiral MDG8426AGW DRYER- GAS
Maytag MDG8500BWW DRYER- GAS
Maytag MDG8506AWA DRYER- GAS
Maytag MDG8506AWW DRYER- GAS
Admiral MDG8550AGW DRYER- GAS
Admiral MDG8550BGW DRYER- GAS
Maytag MDG8600AWQ DRYER- GAS
Maytag MDG8600AWW DRYER
Maytag MDG8757AWQ DRYER- GAS
Maytag MDG8757AWW DRYER- GAS
Maytag MDG9206AWA DRYER- GAS
Maytag MDG9206AWW DRYER- GAS
Maytag MDG9206AXW DRYER- GAS
Maytag MDG9206BWW DRYER- GAS
Maytag MDG9306AWA DRYER- GAS
Maytag MDG9306AWW DRYER- GAS
Maytag MDG9306AXA DRYER- GAS
Maytag MDG9306AXW DRYER- GAS
Maytag MDG9316AWA DRYER- GAS
Maytag MDG9316AWQ DRYER- GAS
Maytag MDG9316AWW DRYER- GAS
Maytag MDG9316AXW DRYER- GAS
Maytag MDG9316BWQ DRYER- GAS
Maytag MDG9316BWW DRYER- GAS
Maytag MDG9357AWA DRYER- GAS
Maytag MDG9357AWW DRYER- GAS
Maytag MDG9360BWW DRYER- GAS
Maytag MDG9390AWW DRYER- GAS
Maytag MDG9390AXW DRYER- GAS
Maytag MDG9390BWW DRYER- GAS
Maytag MDG9420BWW DRYER- GAS
Maytag MDG9520BWQ DRYER- GAS
Maytag MDG9520BWW DRYER- GAS
Maytag MDG9557AWA DRYER- GAS
Maytag MDG9557AWQ DRYER- GAS
Maytag MDG9557AWW DRYER- GAS
Maytag MDG9557AXQ DRYER- GAS
Maytag MDG9557AXW DRYER- GAS
Maytag MDG9557BWQ DRYER- GAS
Maytag MDG9557BWW DRYER- GAS
Maytag MDG9606AWA DRYER- GAS
Maytag MDG9606AWQ DRYER- GAS
Maytag MDG9606AWW DRYER- GAS
Maytag MDG9606AXW DRYER- GAS
Maytag MDG9606BWQ DRYER- GAS
Maytag MDG9606BWW DRYER- GAS
Maytag MDG9700AWM DRYER- GAS
Maytag MDG9700AWW DRYER- GAS
Maytag MDG9706AWA DRYER- GAS
Maytag MDG9706AWW DRYER- GAS
Maytag MDG9766AWW DRYER- GAS
Maytag MDG9766AXW DRYER- GAS
Maytag MDG9800AWQ DRYER- GAS
Maytag MDG9800AWW DRYER- GAS
Maytag MDG9806AWA DRYER- GAS
Maytag MDG9806AWW DRYER- GAS
Maytag MDG9876AWW DRYER- GAS
Maytag MDGT236AWW DRYER- GAS
Maytag MDGT336AWW DRYER- GAS
Maytag MDGT446AWW DRYER- GAS
Frigidaire MDH13TN2
Frigidaire MDH13TN3
Frigidaire MDH15FN1
  #2 (permalink)
Old 02-18-2011, 07:15 AM
Jeff / APP Team's Avatar
Senior Expert
Jeff / APP Team is on a distinguished road
Default
Ok lets test the control panel it see if it is working. Unplug the ribbon cable from the board. You will see an arrow by one if your lines on the cable, this is pin 1. Go to contacts 9 and 16 with your multi-meter and press the off button. You should read around 10,000 ohms through this. You can also check across contacts 11 and 16 and press the start/pause button and it should read the same. If your buttons are responding to the test, then you have a bad board. If they are not working properly, then you have a bad panel. I will list the part numbers here for both parts. Hope this helps.
Part number: AP4044079
Part number: AP4043121
Control panel & top replacement parts for MAYTAG MDG6800AWW DRYER- GAS | AppliancePartsPros.com
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Jeff K. / APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 02-20-2011, 02:59 PM
Junior Member
Default
When I checked 9 & 16 pins my ohm meter zeroed out when I hit the off button. When I checked 11 & 16 pins, ohm meter also zeroed out when I hit the start/pause button. So would that mean that the buttons on my panel are working and that my board would be bad? I appreciate your help.
  #4 (permalink)
Old 02-21-2011, 05:19 AM
Senior Expert
Default
What ohm setting do you have your meter on. You will need to test it on a setting of atleast 10K. You are looking for 10,000 ohms, not 0. Let me know what you find out.
__________________
Jeff K. / APP TEAM
  #5 (permalink)
Old 02-21-2011, 01:59 PM
Junior Member
Default
I had my meter on 20k it zero out just as if you touched the two leads from the meter together.wouldn't that mean the buttons are working or is there supposed to be resistance when the button is pushed in?
  #6 (permalink)
Old 02-22-2011, 05:29 AM
Senior Expert
Default
Ok so it seems the panel is ok. It should read infinity unpressed, and closed pressed. So that would mean you need the control board listed above. Hope this helps.
__________________
Jeff K. / APP TEAM
  #7 (permalink)
Old 02-22-2011, 02:33 PM
Junior Member
Default
Thank you for your time and help
  #8 (permalink)
Old 02-23-2011, 05:59 AM
Senior Expert
Default
Your welcome! Glad we could help!!
__________________
Jeff K. / APP TEAM
  #9 (permalink)
Old 02-24-2011, 03:26 PM
Junior Member
Default
I just received the board and put it in. When I plugged the dryer in it went beep beep beep. Everything seemed to be working fine. Every button was working. I put a towel in on time dry and it was heating up. The dryer was beeping a couple times (beep beep beep) while it was off. Then I tried to put a load of laundry in and it went back to not doing anything the same as before. When I unplug it and plug it back in it beeps 3 times and some of the buttons are lit but they do not work. The dryer will continously beep 3 times every few minutes. I am not sure if there is a significance to the beeping. Please advise. Thank you.
  #10 (permalink)
Old 02-25-2011, 04:46 AM
Senior Expert
Default
Sounds like whatever shorted out your board, has affected the touch panel. The only way for it to beep when off is a shorted keypad. Even though it passed the test. I would recommend changing the touch pad as well.
__________________
Jeff K. / APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Digital control panel frozen ginger1029 Dishwasher Repair 1 02-19-2011 12:31 PM
Control Panel or Electronic Control - which causes blinking panel lights? MarcLCH Dishwasher Repair 1 02-25-2010 03:25 AM
Control panel frozen cburkehunter Dishwasher Repair 2 01-12-2010 05:19 AM
tranformer blew on control panel need specs for new transformer not control panel kaydog2009 Oven Repair (including Ranges and Cooktops) 0 05-11-2009 07:22 AM
Maytag Range COntrol Panel Frozen ewoevo Oven Repair (including Ranges and Cooktops) 6 05-10-2008 10:18 AM
