As stated. First time I tried to start it, it hummed, but would not start, Now it does nothing.. Checked breaker.....OK. Thanks!
First test all your thermal fuses and see if one is blown. They should read closed with a multi-meter. If all your fuses are good the test the door switch. As far as the hum. Check and see if something is stuck in the blower wheel. Let us know what you find.
