| » maytag dryer woes |
Model Number: SDE2606AYW Brand: Maytag Age: 5 - 10 years
Dryer won't dry clothes but heater coil works when I run it without clothes. I have replaced fuse and thermalstat located on heater coil. Any ideas? I have cleaned vent from behind dryer but not under house. Terry
Replacement parts for MAYTAG SDE2606AYW DRYER- ELE | AppliancePartsPros.com See the attachment for the tech sheet. I am assuming that everything looks and sounds OK other than no heat. Your problem is very, very weird. I cannot see the vent causing this problem but that is where I would start. Undo the dryer from the exhaust Run a load If the load dries correctly then you have a vent problem. Clean/check the vent system. Make sure the outside louvers open fully. If you do not want lint in the house. Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load. Both the above will allow you to check the air flow and temp. Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems
__________________
Try to run a load of laundry, without the vent on. If it dry's fine, the vent would be clogged to the outside. Tom ********************************************
| Display Modes | |
| What could it be now? Oven Woes | shokwaves | Oven Repair (including Ranges and Cooktops) | 0 | 11-11-2009 05:32 AM |
| Maytag Performa Washer woes | lehatha | Washer Repair | 3 | 01-05-2009 04:16 AM |
| Maytag dishwasher woes | N Rosemond | Dishwasher Repair | 0 | 10-10-2008 02:16 PM |
| sub zero woes | pacoflyer | Refrigerator & Freezer Repair | 1 | 08-24-2008 07:47 PM |
| Maytag washer woes | pat103051 | Washer Repair | 1 | 05-28-2008 04:09 AM |
