| » Frigidaire elec dryer: Power, but won't start |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: LEQ2152ESO Brand: Frigidaire Age: Less than 1 year
Bought this from lowes as a Scratch and Dent.
Has power to board. You can select cycle,it beeps, board shows timer, etc. Drum light comes on when door is open, off when closed. But when 'start" is pressed, nothing happens. Thermal fuse / limiter checks OK.(Shows continuity, 0.00 reading). I don't have any paperwork for it. Playing around, I found that if i press and hold the "select" button and "cancel" at the same time, the board reads "rE5". I can't find any reference to frigidaire dryer fault codes, so maybe that means nothing. Or maybe I'm doing it wrong.... Is there a fault code system for this dryer? Where else can I look for the problem? Should I go as far at this point as seeing if there power being sent to the motor? ANY advice is greatly appreciated! Dale |
Verify you have 230 volts to the terminal block at the back of dryer. If ok, check for power to the control board, should be labeled where the power goes in the board.
Also, check your thermal fuse on the blower housing. If everything checks ok, replace the control board. Click on your model # to get the part.
__________________
| Display Modes | |
| dryer wont start | debbie | Dryer Repair | 3 | 10-14-2007 03:40 AM |
| Dryer will not start | bob38 | Dryer Repair | 2 | 09-19-2007 07:59 PM |
| Power Outage-Now My Dryer Is dead | Annie | Dryer Repair | 0 | 08-14-2007 08:49 AM |
| Power Problems With Dryer | NESSDIST | Dryer Repair | 0 | 07-29-2007 01:36 PM |
| Tappan Stove elec/control/timer | ccole | Oven Repair (including Ranges and Cooktops) | 1 | 07-27-2007 05:01 PM |
