| dmcglynn |
10-16-2007 12:45 PM |
Drum making noise
I have a Sears Kenmore dryer Model 110-63952. Drum is making a metal on metal sound. The felt seal on the front of the drum has come off. It is still intact however. After researching some I believe this occurred because I affected the drum support when didn't replace all the screws when I attemped to remove the rear panel. After I replace the screws in the back panel so it properly supports the drum, can I use the old felt seal, or do I need a new one? I was gioven Part# 280114 as the replacement felt seal if I need to order. Do you have instructions for this procedure? Thanks
