| » My Dryer only has low heat |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: LER4434AQO Brand: Whirlpool Age: More than 10 years
Can you help?
I'm having troulbe geting my clothes to dry. I am restarting my dryer over and over to dry the clothes. I have some heat, but it seems to be just very low temperature heat. I have taken out the heating element and tested it. It seems to be fine. Do you think I should order the "high limit thermostat" to fix this problem? |
Try it with the vent hose removed from the dryer to see if you may have an air flow problem from the dryer to the outside, also be sure the blower wheel on the motor is not loose....
__________________
-Serving North Central Texas and Southern Oklahoma since 1978. www.samsservicesenter.com |
Can you help?
I'm having troulbe geting my clothes to dry. I am restarting my dryer over and over to dry the clothes. I have some heat, but it seems to be just very low temperature heat. I have taken out the heating element and tested it. It seems to be fine. Do you think I should order the "high limit thermostat" to fix this problem? There is good air flo comming from the back, The air isnt very warm, Could this be the heating element? Terry |
| Display Modes | |
| No Dryer Heat | jackd3 | Dryer Repair | 2 | 10-06-2007 12:32 PM |
| dryer won't heat | deirdre williams | Dryer Repair | 0 | 09-28-2007 03:23 AM |
| gas dryer will not heat | retcop320 | Dryer Repair | 1 | 09-11-2007 05:41 PM |
| gas dryer with no heat | lz7274 | Dryer Repair | 1 | 08-22-2007 04:02 PM |
| dryer heat | karen | Dryer Repair | 0 | 07-23-2007 12:55 PM |
