Discuss
My Dryer only has low heat
 in
Dryer Repair
Can you help? I'm having troulbe geting my clothes to dry. I am restarting my dryer over and over
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » My Dryer only has low heat
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-16-2007, 10:25 AM
rmoss@footprintscarolina. rmoss@footprintscarolina. is offline
Junior Member
rmoss@footprintscarolina. is on a distinguished road
Default My Dryer only has low heat
Model Number: LER4434AQO   Brand: Whirlpool   Age: More than 10 years
Can you help?
I'm having troulbe geting my clothes to dry. I am restarting my dryer over and over to dry the clothes. I have some heat, but it seems to be just very low temperature heat. I have taken out the heating element and tested it. It seems to be fine. Do you think I should order the "high limit thermostat" to fix this problem?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-16-2007, 11:04 AM
Pegi's Avatar
Pegi Pegi is offline
Senior Expert
APP Volunteer
Pegi is on a distinguished road
Arrow
Try it with the vent hose removed from the dryer to see if you may have an air flow problem from the dryer to the outside, also be sure the blower wheel on the motor is not loose....
__________________
-Serving North Central Texas and Southern Oklahoma since 1978.
www.samsservicesenter.com
  #3 (permalink)
Old 10-16-2007, 08:26 PM
TERRY JERREL TERRY JERREL is offline
Junior Member
TERRY JERREL is on a distinguished road
Default
Can you help?
There is good air flo comming from the back, The air isnt very warm, Could this be the heating element?
Terry
  #4 (permalink)
Old 10-18-2007, 03:09 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You will need a meter to check things. Probably a burnt wire somewhere.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No Dryer Heat jackd3 Dryer Repair 2 10-06-2007 12:32 PM
dryer won't heat deirdre williams Dryer Repair 0 09-28-2007 03:23 AM
gas dryer will not heat retcop320 Dryer Repair 1 09-11-2007 05:41 PM
gas dryer with no heat lz7274 Dryer Repair 1 08-22-2007 04:02 PM
dryer heat karen Dryer Repair 0 07-23-2007 12:55 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
