Discuss
Timer on Whirlpool Dryer stopped working
 in
Dryer Repair
I have a basic whirlpool dryer,Model #WED5300SQ0 that is about 2 years old. The timer stopped working. When I start
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Timer on Whirlpool Dryer stopped working
  #1 (permalink)
Old 02-05-2011, 02:27 PM
Junior Member
J Kreimer is on a distinguished road
Default Timer on Whirlpool Dryer stopped working
Brand: Whirlpool   Age: 1 - 5 years
I have a basic whirlpool dryer,Model #WED5300SQ0 that is about 2 years old. The timer stopped working. When I start a load the timer does not move and the dryer never heats up. I have tried different setting and none of them are working. Any suggestions? Is it just the timer or control board behind it or thermostat or any other possibilities?
Ads By Google
  #2 (permalink)
Old 02-06-2011, 08:46 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
A Model number may help others help you.
When you say you tried different cycles did you try timed dry and auto cycles? Just watching to see if the timer advances.
__________________
  #3 (permalink)
Old 02-08-2011, 02:40 PM
Junior Member
Default
Model # WED5300SQ0
  #4 (permalink)
Old 02-08-2011, 02:42 PM
Junior Member
Default
The model number is WED5300SQ0.
  #5 (permalink)
Old 02-08-2011, 03:42 PM
Junior Member
Default
I have tried different setting and sometimes they would move but now they do not.
  #6 (permalink)
Old 02-09-2011, 09:31 AM
Senior Expert
APP Volunteer
Default
Here is the parts breakdown.
Replacement parts for WHIRLPOOL WED5300SQ0 29``ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for your wiring diagram.
The first thing I would check is the power.
The timer is connected directly across the 240 volts is timed dry through Timer Switch 0 contacts TMtoWB and the heater also requires 240 so odds are that you do not have 240.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ge double oven timer has stopped working emkaye Oven Repair (including Ranges and Cooktops) 1 09-26-2010 12:22 AM
Whirlpool Dryer timer test good but not working ctbasscatcher Dryer Repair 1 09-08-2010 01:19 PM
Whirlpool Dryer Stopped Working hentwee Dryer Repair 0 01-14-2010 08:05 AM
Clock/Timer Stopped Working jimyd Oven Repair (including Ranges and Cooktops) 0 07-28-2008 01:33 PM
Whirlpool dryer stopped working rloquist Dryer Repair 1 03-29-2008 12:44 PM
