Discuss
Maytag gas dryer, no heat
 in
Dryer Repair
No heat from Maytag gas dryer LDG9824AAE, it does run. No glow at igniter, don't know where the thermal fuse
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag gas dryer, no heat
  #1 (permalink)
Old 02-04-2011, 02:59 PM
Junior Member
1nwmike is on a distinguished road
Default Maytag gas dryer, no heat
Model Number: LDG9824AAE   Brand: Maytag   Age: More than 10 years
No heat from Maytag gas dryer LDG9824AAE, it does run. No glow at igniter, don't know where the thermal fuse or cycling thermostat is located. Where are they? I presume I should check for continuity on those two items first, is this correct?
Ads By Google
Related Models
Maytag LDG9824AAE Dryer - Gas
Maytag LDG9824AAL Dryer - Gas
Maytag LDG9824AAM Dryer - Gas
Maytag LDG9900 Dryer - Gas
Maytag LDG9900AAL Dryer - Gas
Maytag LDG9900AAW Dryer - Gas
Maytag LDG9900ABL Dryer - Gas
Maytag LDG9900ABW Dryer - Gas
Maytag LDG9900BAL Dryer - Gas
Maytag LDG9900BAW Dryer - Gas
Maytag LDG9900BBL Dryer - Gas
Maytag LDG9900BBW Dryer - Gas
Maytag LDG9900R Dryer - Gas
Maytag LDG9904AAE Dryer - Gas
Maytag LDG9904AAL Dryer - Gas
Maytag LDG9904AAM Dryer - Gas
Admiral LDGA100AAL Dryer - Gas
Admiral LDGA100AAW Dryer - Gas
Admiral LDGA100BAE Dryer - Gas
Admiral LDGA100BAM Dryer - Gas
Admiral LDGA200AAE Dryer - Gas
Admiral LDGA200AAL Dryer - Gas
Admiral LDGA200AAM Dryer - Gas
Admiral LDGA200AAW Dryer - Gas
Admiral LDGA300AGE Dryer - Gas
Admiral LDGA300AGL Dryer - Gas
Admiral LDGA300AGW Dryer - Gas
Admiral LDGA400AAE Dryer - Gas
Admiral LDGA400AAL Dryer - Gas
Admiral LDGA400AAM Dryer - Gas
Admiral LDGA400AAW Dryer - Gas
Admiral LDGA500AAE Dryer - Gas
Admiral LDGA500AAL Dryer - Gas
Admiral LDGA500AAM Dryer - Gas
Admiral LDGA500AAW Dryer - Gas
Hoover LDGH200AAV Dryer - Gas
Hoover LDGH200AGV Dryer - Gas
Maytag LDGS30PC1 Dryer - Gas
Whirlpool LDI3001W0
Whirlpool LDI5521W0
Whirlpool LDI5521W1
Whirlpool LDI5701W0
Whirlpool LDI5701W1
Whirlpool LDI5701W2
Whirlpool LDI5751W0
Whirlpool LDI5751W1
Whirlpool LDI5801W0
Whirlpool LDI5801W1
Whirlpool LDI5921W0
Whirlpool LDI5921W1
Whirlpool LDI6401W0
Whirlpool LDI6401W1
Whirlpool LDI6601W0
Whirlpool LDI6601W1
Whirlpool LDI6601W2
Whirlpool LDI6681W0
Whirlpool LDI6681W1
Whirlpool LDI6681W2
Whirlpool LDI6901W0
Whirlpool LDI7501W0
Whirlpool LDI7801W0
Whirlpool LDI7801W1
Whirlpool LDI8001W0
Whirlpool LDI8801W0
Whirlpool LDI8801W1
Whirlpool LDI9801W0
Whirlpool LDI9801W1
Whirlpool LDI9801W2
Whirlpool LDR3422AN0
Whirlpool LDR3422AW0
Whirlpool LDR3822BN0
Whirlpool LDR3822BW0
Whirlpool LDR3822DQ1
Whirlpool LDR3822DQ2
Whirlpool LDR3822DZ1
Whirlpool LDR3822DZ2
Whirlpool LDR3822HQ0
Whirlpool LDR3822HQ1
Whirlpool LDR3822PQ0 Compact Electric Dryer
Whirlpool LDR3822PQ1 Compact Electric Dryer
Amana LE1007W Dryer - Ele
General Electric LE1032H01 Counter top microwave
General Electric LE1032H02 Counter top microwave
Amana LE1100 Dryer - Ele
Amana LE1102 Washer - Top Loading
General Electric LE1460H01 Electric range
General Electric LE1460H02 Counter top microwave
Whirlpool LE2000XSW0
Amana LE2102L Dryer - Ele
Amana LE2102W Dryer - Ele
Amana LE2400 Dryer - Ele
Amana LE2402 Dryer - Ele
Amana LE2500 Dryer - Ele
Amana LE2502 Dryer - Ele
Amana LE2802 Washer - Top Loading
Amana LE2810 Dryer - Ele
Amana LE2811 Dryer - Ele
Amana LE2812 Washer - Top Loading
Amana LE2902 Dryer - Ele
Amana LE2910 Dryer - Ele
Whirlpool LE3000XKW0
Whirlpool LE3000XMW0
Whirlpool LE3000XMW1
Whirlpool LE3000XMW2
Whirlpool LE3000XPW0
Whirlpool LE3000XSW0
Whirlpool LE3005XPW0
Whirlpool LE3300XPW0
Whirlpool LE3300XSW0
Whirlpool LE3305XPW0
Amana LE3402G Dryer - Ele
Amana LE3402L Dryer - Ele
Amana LE3402W Dryer - Ele
Amana LE3502L Dryer - Ele
Amana LE3502W Dryer - Ele
  #2 (permalink)
Old 02-04-2011, 06:06 PM
Junior Member
Default parts found
Replying to my own post here to help others who might have the same issue: the thermal fuse and the cycling thermostat are both located on the exhaust coming from the drum, accessible from the front. After looking at a copy of the wiring schematics found under the control panel it appeared that on this model the motor would not run if the thermal fuse was blown, I checked it anyway and got continuity. Did not have continuity thru the igniter and once removed could easily see that it was bad. Hopefully replacing that will solve my problem, we'll see.
  #3 (permalink)
Old 02-05-2011, 02:53 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
It will. Tom wwwapplianceeducator.com
  #4 (permalink)
Old 02-07-2011, 08:54 AM
Junior Member
Default
Thanks. Yes that solved the problem, easy fix.
  #5 (permalink)
Old 02-07-2011, 03:47 PM
Senior Expert
APP Volunteer
Default
Great Job!!! That is the way to save the cash!!! Tom ********************************************
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag dryer does not heat cbyrd3 Dryer Repair 0 05-18-2010 02:44 PM
Maytag Gas Dryer Does Not Heat JJAAYYFF Dryer Repair 3 04-22-2009 02:28 PM
Maytag dryer won't heat again Striker Dryer Repair 1 09-01-2008 05:08 PM
Maytag gas dryer with low heat cmgonz Dryer Repair 2 03-24-2008 06:42 PM
Help with Maytag Dryer-won't heat up momto3 Dryer Repair 0 01-23-2008 08:54 AM
