Discuss
Whirlpool Dryer
 in
Dryer Repair
The dryer will start and run until it gets to the cool down cycle it then shuts off and will
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer
  #1 (permalink)
Old 02-04-2011, 10:15 AM
Junior Member
donkris67 is on a distinguished road
Red face Whirlpool Dryer
Model Number: LER5848EQ2   Brand: Whirlpool   Age: 5 - 10 years
The dryer will start and run until it gets to the cool down cycle it then shuts off and will come back on for at least 1 hour what can be the problem cause when it running it works great.
Ads By Google
Related Models
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
Whirlpool LER6611PQ0 29" Electric Dryer
Whirlpool LER6620PQ0 29"electric Dryer
Whirlpool LER6620PQ1 29"electric Dryer
Whirlpool LER6620PT0 29"electric Dryer
Whirlpool LER6620PT1 29"electric Dryer
Whirlpool LER6621PQ0 29" Electric Dryer
Whirlpool LER6634BN0
Whirlpool LER6634BN1
Whirlpool LER6634BN2
Whirlpool LER6634BQ0
Whirlpool LER6634BQ1
Whirlpool LER6634BQ2
Whirlpool LER6634BW0
Whirlpool LER6634BW1
Whirlpool LER6634BW2
Whirlpool LER6634DQ0
Whirlpool LER6634DQ1
Whirlpool LER6634DW0
Whirlpool LER6634DW1
Whirlpool LER6634DZ0
Whirlpool LER6634DZ1
Whirlpool LER6636PW0 29" Electric Dryer
Whirlpool LER6636PW1 29" Electric Dryer
Whirlpool LER6638DQ0
Whirlpool LER6638DQ1
Whirlpool LER6638DW0
Whirlpool LER6638DW1
Whirlpool LER6638DZ0
Whirlpool LER6638DZ1
Whirlpool LER6644DQ0
Whirlpool LER6644DQ1
Whirlpool LER6644DZ0
Whirlpool LER6644DZ1
Whirlpool LER6646BN0
Whirlpool LER6646BN1
Whirlpool LER6646BN2
Whirlpool LER6646BW0
Whirlpool LER6646BW1
Whirlpool LER6646BW2
Whirlpool LER6646DN1
Whirlpool LER6646DW1
Whirlpool LER6646PW0 29" Electric Dryer
Whirlpool LER6646PW1 29" Electric Dryer
Whirlpool LER6848AN0
Whirlpool LER6848AN1
Whirlpool LER6848AN2
Whirlpool LER6848AQ2
Whirlpool LER6848AW0
Whirlpool LER6848AW1
Whirlpool LER6848AW2
Whirlpool LER6848AZ2
Whirlpool LER7620KQ0
Whirlpool LER7620KQ1
Whirlpool LER7620KT0
Whirlpool LER7620KT1
Whirlpool LER7620LG0
Whirlpool LER7620LG1 29"electric Dryer
Whirlpool LER7620LQ0
Whirlpool LER7620LW0
Whirlpool LER7620LW1 29"electric Dryer
Whirlpool LER7646AN0
Whirlpool LER7646AN1
Whirlpool LER7646AN2
Whirlpool LER7646AQ0
Whirlpool LER7646AQ1
Whirlpool LER7646AQ2
Whirlpool LER7646AW0
Whirlpool LER7646AW1
Whirlpool LER7646AW2
Whirlpool LER7646AZ0
Whirlpool LER7646AZ1
Whirlpool LER7646AZ2
Whirlpool LER7646DQ0
Whirlpool LER7646DQ1
Whirlpool LER7646DW0
Whirlpool LER7646DW1
Whirlpool LER7646DZ0
Whirlpool LER7646DZ1
Whirlpool LER7646EQ0
Whirlpool LER7646EQ1
Whirlpool LER7646EQ2
Whirlpool LER7646EZ0
Whirlpool LER7646EZ1
Whirlpool LER7646EZ2
Whirlpool LER7646JQ0
Whirlpool LER7646JT0
Whirlpool LER7648KQ0
Whirlpool LER7648KQ1
Whirlpool LER7648KQ2
Whirlpool LER7648KQ3 29"electric Dryer
Whirlpool LER7648KT0
Whirlpool LER7648KT1
Whirlpool LER7648KT2
Whirlpool LER7648KT3 29"electric Dryer
Whirlpool LER7648PQ0 29" Electric Dryer
Whirlpool LER7648PQ1 29" Electric Dryer
Whirlpool LER7648PT0 29" Electric Dryer
Whirlpool LER7648PT1 29" Electric Dryer
Whirlpool LER7848DQ0
Whirlpool LER7848DQ1
Whirlpool LER7848DZ0
Whirlpool LER7848DZ1
Whirlpool LER7858AN0
Whirlpool LER7858AN1
Whirlpool LER7858AN2
Whirlpool LER7858AW0
Whirlpool LER7858AW1
Whirlpool LER7858AW2
Whirlpool LER8620PG0 29"electric Dryer
Whirlpool LER8620PG1 29"electric Dryer
Whirlpool LER8620PW0 29"electric Dryer
Whirlpool LER8620PW1 29"electric Dryer
Whirlpool LER8648LG0
Whirlpool LER8648LG1 29"electric Dryer
  #2 (permalink)
Old 02-05-2011, 01:03 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL LER5848EQ2 | AppliancePartsPros.com
Are you sure that it always stops when it hits cool down or do you just think it stops then?
If it always stops at the same place on the timer then it would point toward a timer problem.
If you set the timer to the start position, will it start up?
Have you tried different cycle types and heat settings?
For instance air only to see if anything changes.
The reason I ask is that your shut down symptoms sound like the motor is overheating and tripping it's internal thermal protect. You then have to wait for the motor to cool down and the thermal protect to reset before the unit will restart.
Try turning the drum, in the correct direction, it should turn fairly easily. You may want to try this on a couple other units to get a feel for it. You are trying to see if the drum is too hard to turn and is putting too much load on the motor.
Check that the seals in the unit close to the motor/blower are OK and they are not allowing hot air to blow onto the motor.
__________________
  #3 (permalink)
Old 02-05-2011, 12:12 PM
Junior Member
Thank you for the advice I will try these things I appreaciate all the suggestions I can get .
donkris67
__________________
donkris67
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool (KitchenAid) Gas Dryer Dryer Sensor twcombs52 Dryer Repair 1 07-23-2011 02:56 PM
Whirlpool Dryer won't start in dryer mode. hol99 Dryer Repair 4 06-18-2011 06:42 AM
Whirlpool Dryer won't start in dryer mode. hol99 Dryer Repair 7 12-27-2010 03:34 AM
Burned Dryer Plug - Whirlpool Electric Dryer EastCobbSnob Dryer Repair 4 11-17-2009 06:45 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
