Discuss
Dryer won't stop and no heat
 in
Dryer Repair
My dryer won't shut off in any setting, and the heat does not come on. The control knob turns in
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't stop and no heat
  #1 (permalink)
Old 02-03-2011, 09:42 AM
Junior Member
krazykarl05 is on a distinguished road
Default Dryer won't stop and no heat
Model Number: LER4634JQ0   Brand: Whirlpool   Age: 5 - 10 years
My dryer won't shut off in any setting, and the heat does not come on. The control knob turns in all settings but fails to shut down once it reaches the off position. I have to open the door to turn it off. It is also not producing any heat in all settings. I have seen were people experienced one of these problems, but not both at the same time. I am going to start checking various parts, but any suggestions on what might be the problem would be appreciated. I don't want to start replacing parts if they are not causing the problem since some are expensive. This unit is about 10 years old so would I be better off just replacing it? Again any suggestions would be appreciated. Thanks.
Ads By Google
Related Models
Whirlpool LER4634JQ0
Whirlpool LER4634JQ1
Whirlpool LER4634JQ2 29" Electric Dryer
Whirlpool LER4634JT0
Whirlpool LER4634JT1
Whirlpool LER4634JT2 29" Electric Dryer
Whirlpool LER4634JZ0
Whirlpool LER4634PQ0 29" Electric Dryer
Whirlpool LER4634PQ1 29" Electric Dryer
Whirlpool LER4634PT0 29" Electric Dryer
Whirlpool LER4634PT1 29" Electric Dryer
Whirlpool LER5434AN0
Whirlpool LER5434AW0
Whirlpool LER5600HQ0
Whirlpool LER5600HZ0
Whirlpool LER5600JQ0
Whirlpool LER5600JT0
Whirlpool LER5620KQ0
Whirlpool LER5620KQ1
Whirlpool LER5620KQ2 29"electric Dryer
Whirlpool LER5624BN0
Whirlpool LER5624BN1
Whirlpool LER5624BN2
Whirlpool LER5624BW0
Whirlpool LER5624BW1
Whirlpool LER5624BW2
Whirlpool LER5624DQ0
Whirlpool LER5624DQ1
Whirlpool LER5624DW1
Whirlpool LER5624DZ0
Whirlpool LER5624DZ1
Whirlpool LER5634AN0
Whirlpool LER5634AQ0
Whirlpool LER5634AQ1
Whirlpool LER5634AQ2
Whirlpool LER5634AW0
Whirlpool LER5634DQ1
Whirlpool LER5634EQ0
Whirlpool LER5634EZ0
Whirlpool LER5634LG0
Whirlpool LER5634LQ0 29" Electric Dryer
Whirlpool LER5634LT0
Whirlpool LER5634LW0
Whirlpool LER5635LQ0 29"electric Dryer
Whirlpool LER5635LQ1 29"electric Dryer
Whirlpool LER5636DW0
Whirlpool LER5636DW1
Whirlpool LER5636EQ0
Whirlpool LER5636EQ1
Whirlpool LER5636EQ2
Whirlpool LER5636EQ3
Whirlpool LER5636EZ0
Whirlpool LER5636EZ1
Whirlpool LER5636EZ2
Whirlpool LER5636EZ3
Whirlpool LER5636JQ0
Whirlpool LER5636JT0
Whirlpool LER5636KQ0
Whirlpool LER5636KQ1
Whirlpool LER5636KT0
Whirlpool LER5636KT1
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"electric Dryer
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"electric Dryer
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
Whirlpool LER5644EQ2
Whirlpool LER5644EZ0
Whirlpool LER5644EZ1
Whirlpool LER5644EZ2
Whirlpool LER5644JQ0
Whirlpool LER5644JQ1
Whirlpool LER5644JQ2
Whirlpool LER5644JQ3 29"electric Dryer
Whirlpool LER5644JT0
Whirlpool LER5644JT1
Whirlpool LER5644JT2
Whirlpool LER5644JT3 29"electric Dryer
Whirlpool LER5644PQ0 29"electric Dryer
Whirlpool LER5644PQ1 29"electric Dryer
Whirlpool LER5700KQ0
Whirlpool LER5700KQ1
Whirlpool LER5700KT0
Whirlpool LER5700KT1
Whirlpool LER5848EQ0
Whirlpool LER5848EQ1
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
Whirlpool LER6611PQ0 29" Electric Dryer
Whirlpool LER6620PQ0 29"electric Dryer
Whirlpool LER6620PQ1 29"electric Dryer
Whirlpool LER6620PT0 29"electric Dryer
Whirlpool LER6620PT1 29"electric Dryer
Whirlpool LER6621PQ0 29" Electric Dryer
Whirlpool LER6634BN0
  #2 (permalink)
Old 02-03-2011, 11:01 PM
Member
RoboJoe Industries is on a distinguished road
Default
Gas or electric?
Could be as simple as a thermal fuse.
Do you have a meter? Do you know how to use it?
If so, you may call me at (***)***-*** and I will walk you through it.
Otherwise, call a technician.
Last edited by Adam / APP Team : 08-29-2012 at 11:14 AM. Reason: Non-Affiliatted Advertising
  #3 (permalink)
Old 02-03-2011, 11:36 PM
Junior Member
Default
The dryer is electric and I do have a meter. It may be a couple of days before I can take a look, but what should I check first? Thanks for the reply.
  #4 (permalink)
Old 02-03-2011, 11:51 PM
Member
Default
Check your circuit breakers first and make sure you didn't drop a leg.
You need to get inside.
What brand?
Unplug the unit and check continuity on the thermal fuses and the heater element.
Call me when you are ready and I'll help you over the phone.
Have a notebook handy. LOL
Last edited by Adam / APP Team : 08-29-2012 at 11:11 AM. Reason: Non-Affiliatted Advertising
  #5 (permalink)
Old 02-04-2011, 01:07 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL LER4634JQ0 | AppliancePartsPros.com
See the attachment for the wiring diagram.
I am assuming that this unit used to work OK and it is not new to you.
If you did just get it, someone may have messed up the wiring.
Also I am assuming that the timer just keeps going past off in both timed dry and auto modes. The timer motor gets power through a different path depending on the mode.
Sounds like you have 2 problems.
No Stopping:
Unplug the unit and measure across the BK/BU set of timer contacts.
They should open when you are at off.
Be sure to disconnect the wires going to one side of the contacts, just to be sure you do not read an alternate/parallel circuit path.
Could be the contacts are welded shut.
No heat:
Measure across Timer Switch 2 contacts since you are already in the console.
They should be closed in all heating modes.
If OK then check the thermal cutoff / thermostats and then the heating coil.
If the thermal cutoff (Item 6 in Section 3) is blown, there are other things you should check before replacing it.
Thermal Cutoff blown.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer will heat one load and stop? mwpenni Dryer Repair 1 10-28-2009 11:52 AM
Dryer won't heat up and doesn't stop running vbandpb Dryer Repair 3 01-28-2008 07:54 PM
Kenmore dryer/no heat/doesn't stop Utili23 Dryer Repair 1 01-25-2008 03:32 PM
GE Gas Dryer-no heat, doesn't stop tenor_ringer Dryer Repair 1 11-26-2007 02:35 PM
dryer wont heat or stop peter oriol Dryer Repair 0 11-08-2007 08:34 AM
