| » Kenmore 110 series drum won't turn |
Model Number: 110-64082202 Brand: Kenmore Age: 5 - 10 years
My Kenmore Dryer won't turn the drum. When I select a program and then hit 'start' the machine acts normally and the expected time & temperature are displayed but there is no movement or sound coming from the dryer. Here is a breakdown of what I have done so far:
1. With the unit plugged in, I ran the diagnostics. The results were as expected in the service manual. The belt is fine, the connection through to the motor is fine, the idler-pulley appears to be fine and everything looks functional. 2. Tested continuity in the fuses. All of the fuses tested ok. One did not give a continuity result, it was the two prong piece on the blower assembly that is not the motor fuse (perhaps a cycling thermostat). The motor fuse tested fine. Could this be the problem? Can I short the connection to test if it will work? Ads By Google Related Models |
Replacement parts for 110-64082202 models | AppliancePartsPros.com When I look up on AppliancePartsPros the part number you listed it comes up as the thermistor AP3919451 (1/3 down first page). You should not short it. It should be about 10,000 ohms. Here is the tech sheet, see the attachment. Do the motor Test #2.
__________________
- Last edited by denman : 02-03-2011 at 02:29 AM. |
| Display Modes | |
| Series 80 Drum not upright | GerryH | Washer Repair | 3 | 09-17-2010 01:27 PM |
| Kenmore 90 Series drum problem | MattH | Washer Repair | 5 | 02-09-2009 08:49 AM |
| Drum will not turn | David Rivera | Dryer Repair | 1 | 07-11-2008 01:03 PM |
| Admiral Designer Series washer - spins some during agitation; can turn drum while off | John Z | Washer Repair | 1 | 07-03-2008 08:13 PM |
| drum does not turn | MUIRTER | Dryer Repair | 1 | 04-09-2008 05:30 PM |
