Discuss
dryer belt install
 in
Dryer Repair
The dryer belt came loose. I need instructions to install it again or replace it with a new one. Please
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer belt install
  #1 (permalink)
Old 10-14-2007, 10:48 PM
annie57 annie57 is offline
Junior Member
annie57 is on a distinguished road
Unhappy dryer belt install
Brand: Kenmore   Age: 1 - 5 years
The dryer belt came loose. I need instructions to install it again or replace it with a new one. Please HELP.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-15-2007, 04:45 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Really need model # to help.
To put the belt back on, remove front panel and check idler pulley, probably busted or has a bad bearing.
If ok, just rout the belt around the drum with the grooved side against the drum
and placed at the wear mark on the drum.
Reach under the drum,put the idler pulley spring metal into the slot in the frame by the motor pulley. Rout the belt around the pulley and onto the motor pulley.
The belt routing will look like an S. There is ONLY one way belt will go on and keep the tension for the motor to turn the drum.
Also, if your idler pulley is a slide instead of a wheel, throw it away and buy the standard plastic roller type, part # 691366
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Belt removal and install craig miller Dryer Repair 0 08-16-2007 12:40 PM
dryer belt replacement mamasue Dryer Repair 0 08-14-2007 10:00 AM
Replacement of Dryer Belt kcbrandt11 Dryer Repair 0 08-02-2007 03:25 PM
Dryer Tub Belt ColleenR Dryer Repair 0 07-26-2007 09:39 PM
how to put a belt on my dryer radracemom Dryer Repair 1 07-23-2007 05:47 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
