| » Roper dryer |
Model Number: red4340SQ1 Brand: Roper Age: 1 - 5 years
Question: I have a roper dryer that is 3 years old. When I turn it on the dryer gets hot at first; however then it cuts off. The clothes get warm but not enough to dry them. The feel hot and damp when I open the dryer up after the cycle is finished.
What could be the problem??? Ads By Google Related Models |
I would try the following.
Undo the dryer from the exhaust Run a load If the load dries correctly then you have a vent problem. Clean/check the vent system. Make sure the outside louvers open fully. If you do not want lint in the house. Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load. Both the above will allow you to check the air flow and temp. Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems
__________________
| Display Modes | |
| Roper Dryer | dean6883 | Dryer Repair | 1 | 10-13-2010 04:08 PM |
| roper dryer | benjiestep | Dryer Repair | 1 | 11-15-2009 02:56 PM |
| Roper dryer won't run | brandallee3 | Dryer Repair | 5 | 09-01-2009 04:57 AM |
| Help! Roper Dryer | rgvjason | Dryer Repair | 5 | 05-05-2009 09:37 PM |
| Need Roper Dryer help | Mztell | Dryer Repair | 1 | 03-13-2008 06:11 PM |
