| » Gas dryer runs but no heat |
Model Number: DBVH512 Brand: GE Age: 1 - 5 years
Similar to other posts that I've seen, my GE dryer will run but doesn't heat up above room temp. A few days prior to this happening I noticed a slight gas smell. I unplugged everything immediately, shut off the gas at the wall, checked the gas line for leaks (found none) and cleaned out the vent duct while that was accessible, then turned the gas back on.
Since then, no gas smell, but no heat at all either. Is this likely a heating coil or something that is easily replaced? Thanks! Ads By Google Related Models |
It sounds like the ignitor, since you smelled gas. The ignitor could be weak, and barely opening the gas valve, causes it not to light, and therefor the smell og gas. Tom ********************************************
| Display Modes | |
| Dryer runs with no heat but cuts out with heat on | nicholas521 | Dryer Repair | 6 | 01-27-2011 04:19 PM |
| Dryer runs but no heat | Pepe | Dryer Repair | 0 | 02-07-2010 06:14 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer runs no heat, Please help | blindman | Dryer Repair | 10 | 06-03-2009 02:23 PM |
| Dryer runs but does not heat | Garrett | Dryer Repair | 1 | 02-15-2009 06:28 AM |
