Discuss
gas dryer turns off(timer runs) re starts on own??
 in
Dryer Repair
dryer runs about 45 min(even empty) stops spinning... timer ticks and moves re starts itself after about 10 min(without pushing
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » gas dryer turns off(timer runs) re starts on own??
  #1 (permalink)
Old 12-07-2008, 07:21 PM
Junior Member
efniatet is on a distinguished road
Default gas dryer turns off(timer runs) re starts on own??
Model Number: rgs7648eq3   Brand: Roper   Age: More than 10 years
dryer runs about 45 min(even empty) stops spinning... timer ticks and moves re starts itself after about 10 min(without pushing start again) and finishes cycle. was very linty. vacced all out but still does.. seeing that timer still operates and re starts on ownseems like something thinking over heat????? will thermal fuse auto reset? or just blow? and will that still keep timer going? thanks
Related Models
Roper RGS7648EQ3 GAS DRYER
Roper RGS7648EW0 GAS DRYER
Roper RGS7648EW2 GAS DRYER
Roper RGS7648EW3 GAS DRYER
Roper RGS7648JQ0 GAS DRYER
Roper RGS7648JQ1 RESIDENTIAL DRYER
Roper RGS7648KQ1 RESIDENTIAL DRYER
Roper RGS7648KQ2 DRYER
Roper RGS7745PQ0 29" GAS DRYER
Roper RGS7745RQ0 29" GAS DRYER
Roper RGS7745RQ1 29" GAS DRYER
 RGSF3330DW RANGE- S/C F/S GAS
 RGSF5330DT RANGE- S/C F/S GAS
Amana RGT350UD SURFACE UNIT- GAS
Amana RGT350UWW SURFACE UNIT- GAS
Amana RGT650UD SURFACE UNIT- GAS
Amana RGT650UWW SURFACE UNIT- GAS
General Electric RGU32N01 Gas range
General Electric RGU32U01 Gas range
General Electric RGU32U02 Gas range
General Electric RGU3501A Gas range
General Electric RGU6501A Gas range
Roper RGX3514PQ0 29" GAS DRYER
Roper RGX3514RQ0 29" GAS DRYER
Roper RGX3514RQ1 29" GAS DRYER
Roper RGX3519PQ0 29" GAS DRYER
Roper RGX3615EW0 GAS DRYER
Roper RGX4624EN0 GAS DRYER
Roper RGX4625EN0 GAS DRYER
Roper RGX4625EW0 GAS DRYER
Roper RGX4625EW1 DRYERS
Roper RGX4625EW2 GAS DRYER
Roper RGX4625EW3 GAS DRYER
Roper RGX4634JQ0 DRYER
Roper RGX4634KQ1 DRYER
Roper RGX4634KQ2 DRYER
Roper RGX4634KQ3 29" GAS DRYER
Roper RGX4635EN0 GAS DRYER
Roper RGX4635EN1 DRYERS
Roper RGX4635EN2 GAS DRYER
Roper RGX4635EN3 GAS DRYER
Roper RGX4635EQ0 GAS DRYER
Roper RGX4635EQ1 DRYERS
Roper RGX4635EQ2 GAS DRYER
Roper RGX4635EQ3 GAS DRYER
Roper RGX4635EW0 GAS DRYER
Roper RGX4635EW1 DRYERS
Roper RGX4635EW2 GAS DRYER
Roper RGX4635EW3 GAS DRYER
Roper RGX5634JQ0 DRYER
Roper RGX5634JQ1 DRYER
Roper RGX5634KQ1 DRYER
Roper RGX5634KQ2 DRYER
Roper RGX5634KQ3 29" GAS DRYER
Roper RGX5634PQ0 29" GAS DRYER
Roper RGX5635EN0 GAS DRYER
Roper RGX5635EN1 DRYERS
Roper RGX5635EN2 GAS DRYER
Roper RGX5635EN3 GAS DRYER
Roper RGX5635EQ0 GAS DRYER
Roper RGX5635EQ1 DRYERS
Roper RGX5635EQ2 GAS DRYER
Roper RGX5635EQ3 GAS DRYER
Roper RGX5635EW0 GAS DRYER
Roper RGX5635EW1 DRYERS
Roper RGX5635EW2 GAS DRYER
Roper RGX5635EW3 GAS DRYER
Roper RGX5636AL1 GAS DRYER
Roper RGX5636AL2 GAS DRYER
Roper RGX5636AW0 Residential Dryer
Roper RGX5636AW1 GAS DRYER
Roper RGX5636AW2 GAS DRYER
Roper RGX6634PQ0 29" GAS DRYER
Roper RGX6634RQ0 29" GAS DRYER
Roper RGX6634RQ1 29" GAS DRYER
Roper RGX6646AL1 GAS DRYER
Roper RGX6646AL2 GAS DRYER
Roper RGX6646AL3 GAS DRYER
Roper RGX6646AQ2 GAS DRYER
Roper RGX6646AQ3 GAS DRYER
Roper RGX6646AW0 Residential Dryer
Roper RGX6646AW1 GAS DRYER
Roper RGX6646AW2 GAS DRYER
Roper RGX6646AW3 GAS DRYER
Roper RH0500RAW00 CHEST FREEZER
Roper RH0500RDW00 CHEST FREEZER
Roper RH0500REW00 CHEST FREEZER
Roper RH0500REW01 CHEST FREEZER
Roper RH0500REW02 CHEST FREEZER
Roper RH0500RWW00 Freezers*
Roper RH0588RBW00 CHEST FREEZER
Roper RH0588REW00 CHEST FREEZER
Roper RH0588REW01 CHEST FREEZER
Roper RH0588REW02 CHEST FREEZER
Roper RH0599RBW00 CHEST FREEZER
Roper RH0599REW00 CHEST FREEZER
Roper RH0599REW01 CHEST FREEZER
Roper RH0599REW02 CHEST FREEZER
Roper RH0799RBW00 CHEST FREEZER
Roper RH0799REW00 CHEST FREEZER
Roper RH0799REW01 CHEST FREEZER
Roper RH0799REW06 FREEZERS
Jenn-Air RH100 HOOD
Roper RH1000RAW00 Freezers*
Roper RH1000RDW00 CHEST FREEZER
Roper RH1000REW00 CHEST FREEZER
Roper RH1000REW01 CHEST FREEZER
Roper RH1000REW05 CHEST FREEZER
Roper RH1000REW06 FREEZERS
Roper RH1000RYW00 Freezers*
Jenn-Air RH101 HOOD
Roper RH1099RBW00 CHEST FREEZER
Roper RH1099REW00 CHEST FREEZER
Roper RH1099REW06 FREEZERS
Roper RH1200RWW00 Freezers*
Roper RH1200RXW00 Freezers*
Whirlpool RH123 Air-conditioner/heat pump
Whirlpool RH123A1 AIR CONDITIONER
Whirlpool RH123A2 AIR CONDITIONERS
Jenn-Air RH130 HOOD
  #2 (permalink)
Old 12-08-2008, 02:08 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
If it will not start right after it fails, probably a bad motor. AP3094245
__________________
  #3 (permalink)
Old 12-08-2008, 07:19 AM
Junior Member
Default
does motor itself have a self contained thermal fuse etc .motor not noisey or anything.i am thinking does seening re starts without having to push start again. seem to act like a auto rests roll out switch would act on a furnace. thanks again for any help
  #4 (permalink)
Old 12-08-2008, 08:48 AM
Senior Expert
APP Volunteer
Default
There is a thermal cutout in the motor that trips if it overheats and will auto reset once the motor cools down, maybe 20 minutes.
__________________
  #5 (permalink)
Old 12-08-2008, 09:16 AM
Junior Member
Default thanks
ok thanks. that explains why i dont have to restart. i will still try to double check by tryin to get to stop again and make sure power still running to motor. thanks again
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer starts for 10 seconds then turns off and has a brning smell brandon410 Dryer Repair 2 04-29-2010 06:19 PM
Dryer runs, turns, heats, but won't dry nanatoabunch Dryer Repair 2 08-11-2009 06:38 PM
Dryer runs, starts to buzz and gets hot EAS Dryer Repair 6 03-27-2009 12:56 PM
Gas Dryer runs 5 seconds and turns off rseward Dryer Repair 0 01-02-2009 03:57 PM
Dryer timers runs until heat turns on goalie66 Dryer Repair 8 01-03-2008 04:20 PM
