Discuss
Electric dryer will turn, blow cold air BUT not heat.
 in
Dryer Repair
Got as problem w/a electric dryer Whirlpool # LEN2000PW0 It will turn, blow cold air BUT not heat. This is
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Electric dryer will turn, blow cold air BUT not heat.
  #1 (permalink)
Old 01-30-2011, 10:23 AM
Junior Member
rolandvz71 is on a distinguished road
Default Electric dryer will turn, blow cold air BUT not heat.
Model Number: LEN2000PW0   Brand: Whirlpool   Age: 1 - 5 years
This is what I checked continuity so far….
1.Thermal fuse heater --good
2. Thermal fuse motor --good
3.Hi limit thermostat--good
4. Cycling thermostat--good
5. Heater is 10Ω--good
6. Timer motor 2.4KΩ--good
This is what I checked voltage so far….
1.Thermal fuse heater 120v across and 120v to ground each side
2. Thermal fuse motor 120v across and 120v to ground each side
3.Hi limit thermostat 120v across and 120v to ground each side
4. Cycling thermostat 120v across and 120v to ground each side
5. Heater is 10Ω 120v across and 120v to ground each side
6. Timer motor 2.4KΩ 120v across and 120v to ground one side other side was less than 5v
How can I check the centrifugal switch on the motor?
Door switch seem to work I open the door the dryer stops…close the door dryer fires up w/no heat
I received the dryer w/no drawing!
Ads By Google
Related Models
Whirlpool LEN2000PW0 29"electric Dryer
Whirlpool LEN2000PW1 29"electric Dryer
Whirlpool LEN3434AW0
Whirlpool LEN3624BN0
Whirlpool LEN3624BN1
Whirlpool LEN3624BN2
Whirlpool LEN3624BW0
Whirlpool LEN3624BW1
Whirlpool LEN3624BW2
Whirlpool LEN3634DW0
Whirlpool LEN3634DW1
Whirlpool LEP6646AN0
Whirlpool LEP6646AN1
Whirlpool LEP6646AN2
Whirlpool LEP6646AW0
Whirlpool LEP6646AW1
Whirlpool LEP6646AW2
Whirlpool LEP6848AN0
Whirlpool LEP6848AN1
Whirlpool LEP6848AN2
Whirlpool LEP6848AW0
Whirlpool LEP6848AW1
Whirlpool LEP6848AW2
Whirlpool LEP7858AN0
Whirlpool LEP7858AN1
Whirlpool LEP7858AN2
Whirlpool LEP7858AQ2
Whirlpool LEP7858AW0
Whirlpool LEP7858AW1
Whirlpool LEP7858AW2
Whirlpool LEP7858AZ2
Frigidaire LEQ1442ES0 Frigidaire/dryer
Frigidaire LEQ2152EE0 Frigidaire/dryer
Frigidaire LEQ2152ES0 Frigidaire/electric Dryer
Frigidaire LEQ332DS0 Frigidaire/dryer
Whirlpool LEQ5000KQ0
Whirlpool LEQ5000KQ1 29"electric Dryer
Whirlpool LEQ5000KQ2 29"electric Dryer
Whirlpool LEQ5000KW1 29"electric Dryer
Whirlpool LEQ5000KW2 29"electric Dryer
Whirlpool LEQ5000PW0 29"electric Dryer
Frigidaire LEQ6000ES0 Frigidaire/dryer
Frigidaire LEQ6000ES1 Frigidaire/dryer
Frigidaire LEQ6000ES2 Frigidaire/electric Dryer
Frigidaire LEQ642DS0 Frigidaire/dryer
Frigidaire LEQ7000EG0 Frigidaire/dryer
Frigidaire LEQ7000ES0 Frigidaire/dryer
Frigidaire LEQ7000ES1 Frigidaire/dryer
Frigidaire LEQ7000ES2 Frigidaire/dryer
Whirlpool LEQ7000KQ0
Whirlpool LEQ7000KQ1
Whirlpool LEQ7000KQ2
Whirlpool LEQ7030KQ0
Whirlpool LEQ7030KQ1
Whirlpool LEQ7030KQ2 29"electric Dryer
Whirlpool LEQ8000HQ0
Whirlpool LEQ8000HQ1
Whirlpool LEQ8000JQ0
Whirlpool LEQ8000JQ1
Whirlpool LEQ8000JQ2
Whirlpool LEQ8000JQ3 29"electric Dryer
Whirlpool LEQ8000JQ4 Electric Dryer
Whirlpool LEQ8100KQ0
Whirlpool LEQ8100KQ1
Whirlpool LEQ8100KT0
Whirlpool LEQ8100KT1
Whirlpool LEQ8611LG0
Whirlpool LEQ8611LG1 27"electric Dryer
Whirlpool LEQ8611LW0
Whirlpool LEQ8611LW1 27"electric Dryer
Whirlpool LEQ8611PG0 27" Electric Dryer
Whirlpool LEQ8611PG1 27"electric Dryer
Whirlpool LEQ8611PG2 27"electric Dryer
Whirlpool LEQ8611PW0 27" Electric Dryer
Whirlpool LEQ8611PW1 27"electric Dryer
Whirlpool LEQ8611PW2 27"electric Dryer
Whirlpool LEQ8621PG0 27" Electric Dryer
Whirlpool LEQ8621PG1 27"electric Dryer
Whirlpool LEQ8621PG2 27"electric Dryer
Whirlpool LEQ8621PW0 27" Electric Dryer
Whirlpool LEQ8621PW1 27"electric Dryer
Whirlpool LEQ8621PW2 27"electric Dryer
Whirlpool LEQ8800JQ0
Whirlpool LEQ8800JQ1
Whirlpool LEQ8800JT0
Whirlpool LEQ8800JT1
Whirlpool LEQ8857HQ0
Whirlpool LEQ8857HQ1
Whirlpool LEQ8857HZ0
Whirlpool LEQ8857HZ1
Whirlpool LEQ8857JQ0
Whirlpool LEQ8857JQ1
Whirlpool LEQ8857JT0
Whirlpool LEQ8857JT1
Whirlpool LEQ8858HQ0
Whirlpool LEQ8858HQ1
Whirlpool LEQ8858HZ0
Whirlpool LEQ8858HZ1
Whirlpool LEQ8858JQ0
Whirlpool LEQ8858JQ1
Whirlpool LEQ8858JT0
Whirlpool LEQ8858JT1
Whirlpool LEQ8858JZ0
Whirlpool LEQ8858JZ1
Whirlpool LEQ9030PQ0 29"electric Dryer
Whirlpool LEQ9030PQ1 29" Electric Dryer
Whirlpool LEQ9508KQ0
Whirlpool LEQ9508LG0
Whirlpool LEQ9508LW0
Whirlpool LEQ9508LW1 29"electric Dryer
Whirlpool LEQ9508PG0 29"electric Dryer
Whirlpool LEQ9508PG1 29" Electric Dryer
Whirlpool LEQ9508PW0 29"electric Dryer
Whirlpool LEQ9508PW1 29" Electric Dryer
Whirlpool LEQ9557KQ1
Whirlpool LEQ9557KT1
Whirlpool LEQ9558KQ0
Whirlpool LEQ9558KQ1
Whirlpool LEQ9558KT0
Whirlpool LEQ9558KT1
  #2 (permalink)
Old 01-31-2011, 04:54 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL LEN2000PW0 29``ELECTRIC DRYER | AppliancePartsPros.com
Here is the wiring diagram, see the attachment.
Have you checked that the unit is getting 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Also checking to Neutral or earth ground is really not telling you anything as the heater does not use neutral and you cannot tell if you are seeing the L1 or the L2 side.
If you have the 240 volts, I would unplug the unit and check the Timer Switch 1 BK to AH with the timer set mid cycle.
Be sure to disconnect one side to ensure you do not read an alternate/parallel circuit path.
__________________
  #3 (permalink)
Old 01-31-2011, 06:51 AM
Junior Member
Default
yes I am getting 220v to the unit
  #4 (permalink)
Old 01-31-2011, 08:32 AM
Senior Expert
APP Volunteer
Default
I thought you had probably checked it but thought it best to check.
Centrifugal switch can be checked by measuring from the non thermostatted side of the heater (right hand side on the wiring diagram) to L2. Probably pick that up off the terminal strip.
A set of clips on for your meter leads would be useful here.
I personally hate trying to hold leads on to test points with the machine shaking.
Especially when messing with 240 volts.
With the unit set to a mid cycle you should see 240 volts.
When the motor is running it should drop to 0.
__________________
  #5 (permalink)
Old 01-31-2011, 10:25 AM
Junior Member
Default
Yes I am getting 120v from centrifugal switch
  #6 (permalink)
Old 01-31-2011, 04:28 PM
Senior Expert
APP Volunteer
Default
Something is very strange.
You should not be able to get 120 on the heater circuit as it is only connected to 240 volts.
You will see 120 if you have one meter lead on Neutral or earth ground (frame) as you will measure either L1 or L2.
So if your leads are only on the heater circuit then only 240 or 0 is possible.
If there is 120 across the centrifugal switch then there must be something shorted to ground in the heater circuit.
Unplug the unit and both wires to the heating coil.
Then measure form each side to the case/frame.
Both should be infinite ohms (open).
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool electric dryer will not turn on at all bishiman Dryer Repair 4 03-16-2010 01:07 PM
Dryer won't blow heat tlksr98 Dryer Repair 1 09-12-2009 04:54 AM
Kenmore electric dryer dont turn on. WoodsFam Dryer Repair 2 03-31-2009 04:45 PM
Dryer Won't Blow Heat sbechard Dryer Repair 1 07-16-2008 04:38 PM
electric dryer drum won't turn dlt1520 Dryer Repair 0 02-10-2008 07:16 AM
