| » dryer won't run good power at plug |
Model Number: fde648gfso Brand: Frigidaire Age: 5 - 10 years
press start and hold hear timer hum as if it has a motor running and click electric motor does not start where should i start trouble shooting checked pig tail ,its good ,the plug wire thanks all dryer door parts are ok switch not tested yet.
Here are your parts, includes a wiring diagram.
Replacement parts for FRIGIDAIRE FDE648GFS0 Frg(v1) / Dryer | AppliancePartsPros.com checked pig tail ,its good Sorry but I do nor understand what you mean. If the interior light works then you know power (L1 to Neutral) for the motor is OK.. I would check the thermal limiter (fuse) (Item 36 in Section1) first. Unplug the unit. Remove one wire from the fuse and check it with a meter. Should be 0 ohms. If it is blown then replace it and check/clean your vent suystem as this is the most common cause of it going. Not a bad idea to also clean/check your blower wheel. Next would be the door switch and then the start switch.
__________________
| Display Modes | |
| Condensor fan not running. power to the 3wire plug has 11.5 vdc on 2 legs. | h60mech | Refrigerator & Freezer Repair | 1 | 10-16-2010 03:35 PM |
| Dryer does not turn has power to plug and unit | wxperez | Dryer Repair | 2 | 05-24-2009 08:09 AM |
| Convert Kitchen Aid Dryer from 3 Prong Plug to 4 Prong Plug | edd225 | Dryer Repair | 2 | 04-16-2009 06:59 PM |
| No power to Dryer but Have 240 at plug?? | bigredcherokee | Dryer Repair | 3 | 04-16-2009 11:11 AM |
