Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   not drying (http://forum.appliancepartspros.com/dryer-repair/166795-not-drying.html)
scoldoc@gmail.com 01-29-2011 09:43 AM
not drying
Dryer not drying well. I cleaned all lint out of machine and replaced exhaust duct.The element gets red hot but doesnt stay on the whole time. I think that I should probably replace the thermostats . there seems to be 4 different theromstat or cut off type devices.
denman 01-30-2011 03:59 AM
1 Attachment(s)
Replacement parts for KENMORE 11063952101 | AppliancePartsPros.com
Here is the tech sheet, see attachment.
The element gets red hot but doesn't stay on the whole time.
Not sure what you mean. It is normal for te element to turn on/off during the cycle. It is either full on or full off.
Read more: http://forum.appliancepartspros.com/...#ixzz1CWE7i7Yy
Try diagnostics to see if anything comes up.
The unit uses a thermistor to sense the temperature so I would check it with a meter.
Could be you are running off the high limit and may also have a grounded element.
I would do the following first just to be 100% sure you do not still have a venting problem.
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
scoldoc@gmail.com 01-30-2011 06:07 AM
thanks ,good advise. i went to sears and bought a new theromstat and high limit switch , it fixed the problem.
