| » UK, Whirlpool dryer , no-nothing |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: 3LER5436QI Brand: Whirlpool Age: 5 - 10 years
My first post, thank you for any replies
I only know a little about driers.. Friends top loading drier is not working. Twice in the last 3 months it has cut out due to people NEVER emptying the fluff filter.One time it blew the fuse in the plug.One time it needed a new fuse in the plug, the other time the Rcd tripped-and it worked fine again There is power to the programmer, and the on/off switch has continuity but no power. There are two themal cuts out.One on the element , it has a pair of wires and continuity.The cut out on the the fan has two pairs of wires, blue and red.There is continuity across the blue pair , and continuity across the red pair. Are ther any simple things esle I can look at? many thanks Richard |
Hi theome
There are two parts which I would check first. They are: the door switch (#10 on the cabinet parts break down diagram) and thermal fuse (#8 on the bulkhead break down diagram). Good luck. Gene.
__________________
Professional appliance repair services in Orange County, California. |
Many thanks, what great service.
I did remove the bulkhead yesterday and part 8, thermal fuse was taped to one cable loom , no connections! So either its not required on the Uk model , or maybe has been replaced before..though why a blown part wasn't binned is a mystery. I wil go check the door switch today. Richard |
Bit more info.
The thermal fuse is present and has continuity. The taped up item was a resistor? (Juria 10WO, 52 (ohm symbol)k The door switch is also fine. I think thats bout all I can do, unless you can think of anything. I'm loathe to get a programmer, expensive.But we are 20 miles from nearest place an engineer Might come from. Best wishes Richard |
| Display Modes | |
| Whirlpool Dryer won't start | Conrad79 | Dryer Repair | 3 | 10-30-2007 07:54 AM |
| whirlpool gas dryer will not start | dmicare | Dryer Repair | 1 | 09-19-2007 06:16 PM |
| NEED HELP QUICK! Whirlpool Dryer TROUBLES! | jlcglc | Dryer Repair | 1 | 09-19-2007 03:50 AM |
| Whirlpool Dryer - No heat | Warren | Dryer Repair | 0 | 08-14-2007 03:30 PM |
| Whirlpool dryer heat shuts off | Captain Carquest | Dryer Repair | 0 | 08-09-2007 11:37 AM |
