Discuss
UK, Whirlpool dryer , no-nothing
 in
Dryer Repair
My first post, thank you for any replies I only know a little about driers.. Friends top loading drier is
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » UK, Whirlpool dryer , no-nothing
  #1 (permalink)
Old 10-14-2007, 07:26 AM
theome theome is offline
Junior Member
theome is on a distinguished road
Default UK, Whirlpool dryer , no-nothing
Model Number: 3LER5436QI   Brand: Whirlpool   Age: 5 - 10 years
Friends top loading drier is not working. Twice in the last 3 months it has cut out due to people NEVER emptying the fluff filter.One time it blew the fuse in the plug.One time it needed a new fuse in the plug, the other time the Rcd tripped-and it worked fine again
There is power to the programmer, and the on/off switch has continuity but no power.
There are two themal cuts out.One on the element , it has a pair of wires and continuity.The cut out on the the fan has two pairs of wires, blue and red.There is continuity across the blue pair , and continuity across the red pair.
Are ther any simple things esle I can look at?
many thanks Richard
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-14-2007, 10:56 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi theome
There are two parts which I would check first. They are: the door switch (#10 on the cabinet parts break down diagram) and thermal fuse (#8 on the bulkhead break down diagram).
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 10-15-2007, 03:56 AM
Junior Member
Default
Many thanks, what great service.
I did remove the bulkhead yesterday and part 8, thermal fuse was taped to one cable loom , no connections! So either its not required on the Uk model , or maybe has been replaced before..though why a blown part wasn't binned is a mystery. I wil go check the door switch today.
Richard
  #4 (permalink)
Old 10-15-2007, 06:31 AM
Junior Member
Default
Bit more info.
The thermal fuse is present and has continuity.
The taped up item was a resistor? (Juria 10WO, 52 (ohm symbol)k
The door switch is also fine.
I think thats bout all I can do, unless you can think of anything.
I'm loathe to get a programmer, expensive.But we are 20 miles from nearest place an engineer Might come from.
Best wishes Richard
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dryer won't start Conrad79 Dryer Repair 3 10-30-2007 08:54 AM
whirlpool gas dryer will not start dmicare Dryer Repair 1 09-19-2007 07:16 PM
NEED HELP QUICK! Whirlpool Dryer TROUBLES! jlcglc Dryer Repair 1 09-19-2007 04:50 AM
Whirlpool Dryer - No heat Warren Dryer Repair 0 08-14-2007 04:30 PM
Whirlpool dryer heat shuts off Captain Carquest Dryer Repair 0 08-09-2007 12:37 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
