Discuss
Power Surge
 in
Dryer Repair
Dryer was working fine earlier in the day. We had a transformer blow in the area and lost power for
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Power Surge
  #1 (permalink)
Old 12-06-2008, 06:05 PM
Junior Member
targetbill is on a distinguished road
Default Power Surge
Model Number: MDET446AYW   Brand: Maytag   Age: 1 - 5 years
Dryer was working fine earlier in the day. We had a transformer blow in the area and lost power for a couple hours. NOw the power is back on, the breakers are fine, the drum light works, the dial lights work, but the dryer will not run. NO humming, nothing. Drum spins by hand with resistance so belts seems to be OK. Any ideas would be helpful. 5 kids lots of laundry!!
Ads By Google
Related Models
Maytag MDET446AYW Dryer - Ele
Maytag MDET446AZW Dryer - Ele
Maytag MDG100PN1 Dryer - Gas
Maytag MDG100PN1L Dryer - Gas
Maytag MDG100PN1W Dryer - Gas
Maytag MDG10CSAAL Dryer - Gas
Maytag MDG10CSAAW Dryer - Gas
Maytag MDG10CSABL Dryer - Gas
Maytag MDG10CSABW Dryer - Gas
Maytag MDG10CSAGL Dryer - Gas
Maytag MDG10CSAGW Dryer - Gas
Maytag MDG10CSAKL Dryer - Gas
Maytag MDG10CSEGL Dryer - Gas
Maytag MDG10CSEGW Dryer - Gas
Maytag MDG10DAAAL Dryer - Gas
Maytag MDG10DAAAW Dryer - Gas
Maytag MDG10DAABL Dryer - Gas
Maytag MDG10DAABW Dryer - Gas
Maytag MDG10MNAAW Dryer - Gas
International MDG10MNAGW Dryer - Gas
Maytag MDG10MNEGW Dryer - Gas
Maytag MDG10PDAAL Dryer - Gas
Maytag MDG10PDAAW Dryer - Gas
Maytag MDG10PDABL Dryer - Gas
Maytag MDG10PDABW Dryer - Gas
Maytag MDG10PDEGL Dryer - Gas
Maytag MDG10PDEGW Dryer - Gas
Maytag MDG10PRAAW Dryer - Gas
Maytag MDG10PSABW Dryer - Gas
Maytag MDG10PSAGL Dryer - Ele
Maytag MDG10PSAGW Dryer - Ele
Frigidaire MDG116RBW0 Frg(v1) / 27 " Gas Dryer
Frigidaire MDG116RBW1 Frg(v0) / Gas Dryer
Maytag MDG11CSAAL Dryer - Gas
Maytag MDG11CSAAW Dryer - Gas
Maytag MDG11CSABW Dryer - Gas
Maytag MDG11CSAGL Dryer - Gas
Maytag MDG11CSAGW Dryer - Gas
Maytag MDG11CSEGL Dryer - Gas
Maytag MDG11CSEGW Dryer - Gas
Maytag MDG11MNAAW Dryer - Gas
Maytag MDG11MNAGW Dryer - Gas
Maytag MDG11MNEGW Dryer - Gas
Maytag MDG11PDAAL Dryer - Gas
Maytag MDG11PDAAW Dryer - Gas
Maytag MDG11PDABL Dryer - Gas
Maytag MDG11PDABW Dryer - Gas
Maytag MDG11PDAGL Dryer - Gas
Maytag MDG11PDAGW Dryer - Gas
Maytag MDG11PDEGL Dryer - Gas
Maytag MDG11PDEGW Dryer - Gas
Maytag MDG120P1HW Dryer - Gas
Maytag MDG120PHVW Dryer - Gas
Maytag MDG12CSAAL Dryer - Gas
Maytag MDG12CSAAW Dryer - Gas
Maytag MDG12CSABL Dryer - Gas
Maytag MDG12CSABW Dryer - Gas
Maytag MDG12CSAGW Dryer - Gas
Maytag MDG12CSEGW Dryer - Gas
Maytag MDG12MNAAW Dryer - Gas
Maytag MDG12MNAGW Dryer - Gas
Maytag MDG12MNEGW Dryer - Gas
Maytag MDG12PDAAL Dryer - Gas
Maytag MDG12PDAAW Dryer - Gas
Maytag MDG12PDABL Dryer - Gas
Maytag MDG12PDABW Dryer - Gas
Maytag MDG12PDBAL Dryer - Gas
Maytag MDG12PDBAW Dryer - Gas
Maytag MDG12PDBBL Dryer - Gas
Maytag MDG12PDBBW Dryer - Gas
Maytag MDG12PRAAW Dryer - Gas
Maytag MDG12PRBAW Dryer - Gas
Maytag MDG12PRBBW Dryer - Gas
Maytag MDG12PSABW Dryer - Gas
Maytag MDG12PSAGW Dryer - Gas
Maytag MDG12PSBAW Dryer - Gas
Maytag MDG12PSBBW Dryer - Gas
Maytag MDG13CSAAL Dryer - Gas
Maytag MDG13CSAAW Dryer - Gas
Maytag MDG13CSABW Dryer - Gas
Maytag MDG13CSAGW Dryer - Gas
Maytag MDG13CSAKL Dryer - Gas
Maytag MDG13CSEGW Dryer - Gas
Maytag MDG13MNAAW Dryer - Gas
Maytag MDG13PDAAL Dryer - Gas
Maytag MDG13PDAAW Dryer - Gas
Maytag MDG13PDABL Dryer - Gas
Maytag MDG13PDABW Dryer - Gas
Maytag MDG13PDAGW Dryer - Gas
Maytag MDG13PDBAL Dryer - Gas
Maytag MDG13PDBAW Dryer - Gas
Maytag MDG13PDBBL Dryer - Gas
Maytag MDG13PDBBW Dryer - Gas
Maytag MDG13PDEGW Dryer - Gas
Maytag MDG13PRAAW Dryer - Gas
Maytag MDG13PRBAW Dryer - Gas
Maytag MDG14PDAAL Dryer - Gas
Maytag MDG14PDAAQ Dryer - Gas
Maytag MDG14PDAAW Dryer - Gas
Maytag MDG14PDAEW Dryer - Gas
Maytag MDG14PDAGW Dryer - Gas
Maytag MDG14PDSAW Dryer - Gas
Maytag MDG14PNAEW Dryer - Gas
Maytag MDG14PNAGW Dryer - Gas
Maytag MDG14PNAWW Dryer - Gas
Maytag MDG14PNSAW Dryer - Gas
Maytag MDG14PRAWW Dryer - Gas
Maytag MDG14PRAXW Dryer - Gas
Maytag MDG14PSABW Dryer - Gas
Maytag MDG14PSAGW Dryer - Gas
Maytag MDG16CSAEW Dryer - Gas
Maytag MDG16CSAGW Dryer - Gas
Maytag MDG16CSAKA Dryer - Gas
Maytag MDG16CSAKQ Dryer - Gas
Maytag MDG16CSAWA Dryer - Gas
Maytag MDG16CSAWQ Dryer - Gas
Maytag MDG16CSAWW Dryer - Gas
Maytag MDG16CSAXW Dryer - Gas
International MDG16CSBGW Dryer - Gas
Maytag MDG16CSBWQ Dryer - Gas
  #2 (permalink)
Old 12-07-2008, 09:19 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
This is the thermal fuse it is mounted on the heater housing. This could shut the whole unit down. It could be the door switch too, but, with a surege, it is most likely, the thermal fuse. Be sure the unit has power. Tom ********************************************
  #3 (permalink)
Old 12-07-2008, 12:21 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here is your parts breakdown
Model MDET446AYW
Here is a tech sheet and a service manual all be not much of a service manual
http://www.servicematters.com/maytag...s/16027523.pdf
http://www.servicematters.com/maytag...s/16026315.pdf
Hopefully it is the switch or fuse.
The unit has a circuit board and the fastest fuse in the world is an electronic component. They will blow long before a fuse starts to melt. If it is the main board you may want to inquire at your hydro company. I know our company will compensate if they cause the problem re: brown outs etc.
Turn your breaker off/on slowly or better yet check it with a meter for 240 volts. Could be you have lost half your line.
On most units the lights and the motor use the same side of the line. Yours looks like it uses L1 for the lights but L2 for the motor.
Often half the line can drop out and not blow the breaker.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Had a power surge steve Lute Microwave Repair 0 09-01-2009 07:23 AM
Power Surge jvhaney Dryer Repair 1 04-14-2009 03:37 PM
Power surge stopher Oven Repair (including Ranges and Cooktops) 2 03-18-2009 06:49 AM
Power Surge Damage jeparady Oven Repair (including Ranges and Cooktops) 0 02-13-2009 06:07 PM
power surge tbarner Refrigerator & Freezer Repair 1 09-17-2007 09:34 AM
