| » Belt Spinning on Motor Wheel, no Tub Movement |
Model Number: LWA30AW Brand: Amana Age: 5 - 10 years
My washer tub stopped spinning, so I checked underneath and the belt was broken. I ordered a new belt and replaced it, but the belt does not turn with the motor wheel. The motor turns fine, but it does not turn the belt. the Idler mechanism seems to be doing its job just fine. I manually tried turning the belt and it was hard to turn. I can't see anything else wrong. The tub is just hard to turn. I can turn it until the tub turns about one half rotation, and then it gets real hard. What can I do? Am I in for a new washer
Thanks much, Sean Ads By Google Related Models |
| Display Modes | |
| Motor squeeling like a hampster wheel. | Andyd5 | Refrigerator & Freezer Repair | 3 | 11-16-2010 01:59 AM |
| motor turns easily when I pull belt, but fault code manual says to remove belt first | kenrepair | Washer Repair | 0 | 10-21-2010 05:58 AM |
| How Do You Remove Blower Wheel From Motor Shaft? | craigapple | Dryer Repair | 4 | 07-29-2010 10:03 PM |
| cannot remove motor from blower wheel | GSPoulin | Dryer Repair | 3 | 04-13-2010 07:34 AM |
| Unable to get blower fan wheel off motor | gmoliver | Dryer Repair | 1 | 02-17-2010 01:10 PM |
