Discuss
Electric Dryer Problem
 in
Dryer Repair
I set the timer for 45 minutes, the dryer heats up, runs for approx 2-5 minutes then shuts off,..timer is
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Electric Dryer Problem
  #1 (permalink)
Old 12-06-2008, 06:39 AM
Junior Member
GOBISH is on a distinguished road
Default Electric Dryer Problem
Model Number: LER4634EQ1   Brand: Whirlpool   Age: 5 - 10 years
I set the timer for 45 minutes, the dryer heats up, runs for approx 2-5 minutes then shuts off,..timer is still working,... door is still closed.
Any suggestions what the problem might be??
Ads By Google
Related Models
Whirlpool LER4634EQ1
Whirlpool LER4634EQ2
Whirlpool LER4634EW0
Whirlpool LER4634EZ0
Whirlpool LER4634EZ1
Whirlpool LER4634EZ2
Whirlpool LER4634JQ0
Whirlpool LER4634JQ1
Whirlpool LER4634JQ2 29" Electric Dryer
Whirlpool LER4634JT0
Whirlpool LER4634JT1
Whirlpool LER4634JT2 29" Electric Dryer
Whirlpool LER4634JZ0
Whirlpool LER4634PQ0 29" Electric Dryer
Whirlpool LER4634PQ1 29" Electric Dryer
Whirlpool LER4634PT0 29" Electric Dryer
Whirlpool LER4634PT1 29" Electric Dryer
Whirlpool LER5434AN0
Whirlpool LER5434AW0
Whirlpool LER5600HQ0
Whirlpool LER5600HZ0
Whirlpool LER5600JQ0
Whirlpool LER5600JT0
Whirlpool LER5620KQ0
Whirlpool LER5620KQ1
Whirlpool LER5620KQ2 29"electric Dryer
Whirlpool LER5624BN0
Whirlpool LER5624BN1
Whirlpool LER5624BN2
Whirlpool LER5624BW0
Whirlpool LER5624BW1
Whirlpool LER5624BW2
Whirlpool LER5624DQ0
Whirlpool LER5624DQ1
Whirlpool LER5624DW1
Whirlpool LER5624DZ0
Whirlpool LER5624DZ1
Whirlpool LER5634AN0
Whirlpool LER5634AQ0
Whirlpool LER5634AQ1
Whirlpool LER5634AQ2
Whirlpool LER5634AW0
Whirlpool LER5634DQ1
Whirlpool LER5634EQ0
Whirlpool LER5634EZ0
Whirlpool LER5634LG0
Whirlpool LER5634LQ0 29" Electric Dryer
Whirlpool LER5634LT0
Whirlpool LER5634LW0
Whirlpool LER5635LQ0 29"electric Dryer
Whirlpool LER5635LQ1 29"electric Dryer
Whirlpool LER5636DW0
Whirlpool LER5636DW1
Whirlpool LER5636EQ0
Whirlpool LER5636EQ1
Whirlpool LER5636EQ2
Whirlpool LER5636EQ3
Whirlpool LER5636EZ0
Whirlpool LER5636EZ1
Whirlpool LER5636EZ2
Whirlpool LER5636EZ3
Whirlpool LER5636JQ0
Whirlpool LER5636JT0
Whirlpool LER5636KQ0
Whirlpool LER5636KQ1
Whirlpool LER5636KT0
Whirlpool LER5636KT1
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"electric Dryer
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"electric Dryer
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
Whirlpool LER5644EQ2
Whirlpool LER5644EZ0
Whirlpool LER5644EZ1
Whirlpool LER5644EZ2
Whirlpool LER5644JQ0
Whirlpool LER5644JQ1
Whirlpool LER5644JQ2
Whirlpool LER5644JQ3 29"electric Dryer
Whirlpool LER5644JT0
Whirlpool LER5644JT1
Whirlpool LER5644JT2
Whirlpool LER5644JT3 29"electric Dryer
Whirlpool LER5644PQ0 29"electric Dryer
Whirlpool LER5644PQ1 29"electric Dryer
Whirlpool LER5700KQ0
Whirlpool LER5700KQ1
Whirlpool LER5700KT0
Whirlpool LER5700KT1
Whirlpool LER5848EQ0
Whirlpool LER5848EQ1
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
Whirlpool LER6611PQ0 29" Electric Dryer
  #2 (permalink)
Old 12-06-2008, 07:07 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here is your parts breakdown
Model LER4634EQ1
Here is a tech sheet
https://www.servicematters.com/docs/...%203406688.pdf
Could be a couple things
Perhaps the door switch is just closing so the vibration or clothes hitting it is opening it turning off the dryer. By the look of it you may be able to bend the switch actuator so it closes the switch more positively. Could also just be the switch itself is going intermittent.
Perhaps your motor is overheating and the thermal cutoff is tripping.
Can you restart the dryer right away?
Usually it takes a couple minutes for and overheated motor cutoff to reset.
So if it restart right away it is unlikely to be the motor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador C30 Electric: Control problem Thermadorian Oven Repair (including Ranges and Cooktops) 3 09-24-2009 11:39 AM
Bosch electric oven problem madeline1234567 Oven Repair (including Ranges and Cooktops) 0 08-08-2009 03:22 PM
Electric dryer problem lq9655 Dryer Repair 2 10-31-2008 05:41 AM
Electric Dryer Start Problem Homemaker Dryer Repair 1 11-19-2007 07:52 PM
whirlpool electric wall oven problem devdry Oven Repair (including Ranges and Cooktops) 1 09-15-2007 10:30 PM
