Discuss
Amana Dryer will not stop on Auto Cycles
 in
Dryer Repair
Good Evening. I have an electric Amana dryer that will not turn off when set to either of the two
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Amana Dryer will not stop on Auto Cycles
  #1 (permalink)
Old 01-25-2011, 07:35 PM
Junior Member
Tmcjury is on a distinguished road
Default Amana Dryer will not stop on Auto Cycles
Model Number: ALE230RAW   Brand: Amana   Age: 5 - 10 years
Good Evening.
I have an electric Amana dryer that will not turn off when set to either of the two automatic cycles. It definitely heats up and seems to cycle through temperatures, because sometimes the clothes are hot, other times they are just warm.
One other (possibly important) peice of information...I took the dryer apart to replace some pulleys. It all went back together fine and has been working for a year, but I recall some confusion about the three wires that connect to the door swithc...Is it possible they are mixed up on the wrong prongs? Would that matter? THanks.
Ads By Google
Related Models
Amana ALE230RAW Dryer - Ele
Amana ALE230RCW Dryer - Ele
Amana ALE331RAC Dryer - Ele
Amana ALE331RAW Dryer - Ele
Amana ALE331RCW Dryer - Ele
Amana ALE443RAC Dryer - Ele
Amana ALE443RAW Dryer - Ele
Amana ALE443RCW Dryer - Ele
Amana ALE565SAC Dryer - Ele
Amana ALE565SAW Dryer - Ele
Amana ALE643RAC Dryer - Ele
Amana ALE643RAW Dryer - Ele
Amana ALE643RBC Dryer - Ele
Amana ALE643RBW Dryer - Ele
Amana ALE643RCW Dryer - Ele
Amana ALE665SAC Dryer - Ele
Amana ALE665SAW Dryer - Ele
Amana ALE866SAC Dryer - Ele
Amana ALE866SAW Dryer - Ele
Amana ALE866SBC Dryer - Ele
Amana ALE866SBW Dryer - Ele
Amana ALE866SCW Dryer - Ele
Amana ALE868QAW Dryer - Ele
Amana ALE868QCW Washer - Top Loading
Amana ALE956EAC Dryer - Ele
Amana ALE956EAW Dryer - Ele
Whirlpool ALF12420
Whirlpool ALF15040
Whirlpool ALF20040
Whirlpool ALF21040
Whirlpool ALF24040
Whirlpool ALFE0940
Whirlpool ALFH0820
Whirlpool ALFW0940
Amana ALG120RAW Dryer - Gas
Amana ALG230RAW Dryer - Gas
Amana ALG230RCW Dryer - Gas
Amana ALG331RAC Dryer - Gas
Amana ALG331RAW Dryer - Gas
Amana ALG331RMC Dryer - Gas
Amana ALG331RMW Dryer - Gas
Amana ALG443RAC Dryer - Gas
Amana ALG443RAW Dryer - Gas
Amana ALG443RCW Dryer - Gas
Amana ALG565SAC Dryer - Gas
Amana ALG565SAW Dryer - Gas
Amana ALG643RAC Dryer - Gas
Amana ALG643RAW Dryer - Gas
Amana ALG643RBC Dryer - Gas
Amana ALG643RBW Dryer - Gas
Amana ALG643RMC Dryer - Gas
Amana ALG643RMC1 Washer - Top Loading
Amana ALG643RMW Washer - Top Loading
Amana ALG643RMW1 Washer - Top Loading
Amana ALG665SAC Dryer - Gas
Amana ALG665SAW Dryer - Gas
Amana ALG866SAC Dryer - Gas
Amana ALG866SAW Dryer - Gas
Amana ALG866SBC Dryer - Gas
Amana ALG866SBW Dryer - Gas
Amana ALG866SCW Dryer - Gas
Amana ALG868QAW Dryer - Gas
Amana ALG868QCW Washer - Top Loading
Amana ALG956EAC Dryer - Gas
Amana ALG956EAW Dryer - Gas
Whirlpool ALJ00520
Whirlpool ALJ07520
Whirlpool ALJ10020
Whirlpool ALJ12020
Whirlpool ALJ18040
General Electric ALM15DAM1 Room air conditioner
General Electric ALM18DAM1 Zoneline
International ALR1100AJQ Range - F/s Std Gas
International ALR1100AJW Range - F/s Std Gas
International ALR1420BDQ Range - F/s Std Gas
International ALR1420BDW Range - F/s Std Gas
Admiral ALR1450AJW Range - F/s Std Gas
International ALR1450BJW Range - F/s Std Gas
International ALR5715QDQ Range - S/c F/s Gas
International ALR5715QDS Range - S/c F/s Gas
International ALR5715QDW Range - S/c F/s Gas
Amana ALW110RAW Washer - Top Loading
Amana ALW210RAW Washer - Top Loading
Amana ALW210RMC Washer - Top Loading
Amana ALW210RMW Washer - Top Loading
International ALW221RJW Washer - Top Loading
Amana ALW410DAW Washer - Top Loading
Amana ALW430RAC Washer - Top Loading
Amana ALW430RAW Washer - Top Loading
Amana ALW432RAW  Washer - Top Loading
Amana ALW450QAC Washer - Top Loading
Amana ALW450QAW Washer - Top Loading
Amana ALW480DAC Washer - Top Loading
Amana ALW480DAW Washer - Top Loading
Amana ALW540RAC Washer - Top Loading
Amana ALW540RAW Washer - Top Loading
Amana ALW540RMC Washer - Top Loading
Amana ALW540RMW Washer - Top Loading
  #2 (permalink)
Old 01-26-2011, 06:45 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
The door switch issue is not causing this. If it works on timed drying then I would use it that way, as it might be the timer which is pretty expensive.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 80 series dryer will not stop in auto-mode arsenalap Dryer Repair 1 01-21-2011 04:01 AM
Amana Dryer - Won't stop when door opens jpcharlton Dryer Repair 0 08-24-2010 11:48 AM
Amana Dryer does not stop in Auto/delecate dearks Dryer Repair 3 03-10-2009 06:22 PM
Amana gas dryer Does not stop in Auto/ Delecate dearks Dryer Repair 0 03-07-2009 03:09 PM
dryer timer auto cycles don't work mikedudl Dryer Repair 0 04-29-2008 09:52 AM
