| » Whirlpool Electric Dryer won't start. |
Model Number: LER7646EQ0 Brand: Whirlpool Age: 5 - 10 years
My dryer has suddenly stopped working. It was drying a load when it stopped. When the start button is pushed there is nothing happening. The timer still is clicking so I know that there is power and not a blown breaker and the push to start switch has continuity. I have replaced the motor once already a couple of years ago but it does not make any noise as if it is trying to run, just total silence. Is there a possibility that the timer is bad or some safety fuse has tripped and if so how would I check and replace it?
Here is your parts breakdown
Model LER7646EQ0 Here is a tech sheet https://www.servicematters.com/docs/...%203401735.pdf You will see that there is a Thermal Fuse in the motor circuit. I believe this is Item 7 in Section 3 of the parts breakdown. If you do not have a meter to check it. You could short the wires together, tape them up so they cannot short to anything and give it a try. If blown replace it. Do not leave it like this as this is a fire safety device. Give the inside of the unit a good cleaning. Also clean and check your vent system. Something caused it to blow. If both are clean check that the blower is OK.
__________________
The thermal fuse is in the back of the dryer, and white in color, and is about an inch and a half long, and a half inch wide. Tom www.********************************************
| Display Modes | |
| GE electric dryer won't start | aqrose | Dryer Repair | 1 | 11-30-2009 08:31 PM |
| Electric Whirlpool dryer wont start | drew85205 | Dryer Repair | 1 | 11-05-2009 03:56 PM |
| Whirlpool Electric Dryer doesn't start until timer reaches cool down cycle | noclaf1 | Dryer Repair | 6 | 09-03-2009 08:28 AM |
| Whirlpool electric dryer will not start | graham | Dryer Repair | 3 | 02-27-2009 08:07 AM |
| Whirlpool Electric dryer won't start | JakeRose | Dryer Repair | 1 | 07-29-2008 07:09 AM |
