Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Noise at the front of the tub (http://forum.appliancepartspros.com/dryer-repair/165201-noise-front-tub.html)
Psycho S.G. 01-25-2011 11:28 AM
Attempting to repair noises in front of tub( Nor rear Shim as I can tell ). Very light loads no noise. Heavy loads , squeaking noises front tub. Will tub be damaged or minor cleaning up rough edges to. Not used extensively after squeak started ( Maybe 2 W.K.S.) After looking at your parts picture part # 313, 316, & part 312-set are the needed? Serial # is :GL732118A. Hopefully this gives you the info to make decisions. Psycho S.G. Why get frustrated as, it never helps, Thanks:)
sidfink43 01-26-2011 06:42 PM
Those parts should do the trick for you.
Psycho S.G. 01-26-2011 11:44 PM
A.P.P. comes thru as usual
Been with A.P.P for years. If you aren't , get your head out of where the sun doesn't shine. Get a clue!
Quote:
Psycho S.G. 01-27-2011 11:59 AM
As Usual you guy's come through as usual.
Sid Fink & the rest at A.P.P. are there with a quick response as they always do. Early arrival on parts. My son will be up tomorrow to complete the job. Still have the diagram you provided me. You know where I live at & the dinner & drinks are on the house!!! Psycho S.G.!!!!!!:)
