Discuss
Dryer runs but will not heat
 in
Dryer Repair
As the title suggests, my dryer runs but will not heat. I have checked the following: heating element, has continuity
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer runs but will not heat
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-12-2007, 07:02 PM
falgmatp falgmatp is offline
Junior Member
falgmatp is on a distinguished road
Default Dryer runs but will not heat
Model Number: 110.63952101   Brand: Kenmore   Age: 1 - 5 years
Thermal Cut-off, has continuity
Hi-temp thermostat, has continuity
Thermal Fuse, has continuity
Thermistor, does not have continuity (I don't believe that it should)
Does anyone have any suggestions about what else I could look for?
Also, I have confirmed that I have 240V to dryer while running.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-14-2007, 03:33 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Check your service sheet found behind the control panel. Most thermistors at room temperature are 1000 ohms, just measure, if way off replace it.
If ok you just might have a burnt wire somewhere.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer has no heat but runs Ron L. Dryer Repair 6 07-17-2008 08:09 PM
Dryer runs but doesn't heat Junie15 Dryer Repair 4 09-23-2007 09:09 AM
Dryer runs no heat glennb Dryer Repair 1 08-10-2007 10:24 AM
Dryer runs no heat Wesley Dryer Repair 3 07-27-2007 11:23 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
