| » Dryer runs but will not heat |
Model Number: 110.63952101 Brand: Kenmore Age: 1 - 5 years
As the title suggests, my dryer runs but will not heat. I have checked the following:
heating element, has continuity Thermal Cut-off, has continuity Hi-temp thermostat, has continuity Thermal Fuse, has continuity Thermistor, does not have continuity (I don't believe that it should) Does anyone have any suggestions about what else I could look for? Also, I have confirmed that I have 240V to dryer while running. |
Check your service sheet found behind the control panel. Most thermistors at room temperature are 1000 ohms, just measure, if way off replace it.
If ok you just might have a burnt wire somewhere.
__________________
| Display Modes | |
| Dryer has no heat but runs | Ron L. | Dryer Repair | 6 | 07-17-2008 09:09 PM |
| Dryer runs but doesn't heat | Junie15 | Dryer Repair | 4 | 09-23-2007 10:09 AM |
| Dryer runs no heat | glennb | Dryer Repair | 1 | 08-10-2007 11:24 AM |
| Dryer runs no heat | Wesley | Dryer Repair | 3 | 07-28-2007 12:23 AM |
