| » Where's the thermal fuse? |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: 110.66912691 Brand: Kenmore Age: 5 - 10 years
My dryer stopped working. I checked the voltage at the wall outlet and it runs 241 VAC. The door switch works and the thermostat switch (near the door switch on the inside of the dryer) also works (checked with voltage meter). I attempted to take off the back panel to find the thermal fuse, but the sucker would not budge. The timer works (ticks), but the start switch seems dead. The vent is clear.
Help! deburrito ![]() |
Go to the sears site sears3.com for take apart info, your thermal fuse may be behind the front panel on the blower housing. This site will give a part # that you can use at appliancepartspros to order.
__________________
Normally it's sears3.com but it's not working right now. Try www.********.com Sorry, my misstake.
__________________
__________________
Send me an email at inspireme17@yahoo.com
__________________
__________________
Here are the diagrams:
- Top and console - Cabinet - Bulkhead Thermal fuse is number 59 on the Bulkhead diagram. - Replacement thermal fuse, if you need one. |
The best way to get to Sears is WWW3.sears.com
Last edited by Clint : 10-25-2007 at 01:28 PM. Reason: correct url format in reply |
| Display Modes | |
| Help with Replacing Thermal Cutoff Kit | ReagaNoah | Dryer Repair | 4 | 08-16-2008 03:17 PM |
| Need to locate microwave fuse location? | marksworld | Microwave Repair | 2 | 10-02-2007 02:55 PM |
| Thermal fuse location | Dbowls | Dryer Repair | 4 | 08-29-2007 02:37 PM |
| Microwave has no power, replaced fuse 1.5yro | scress | Microwave Repair | 1 | 08-27-2007 03:36 PM |
| my fridge keeps tripping switch in fuse box | jamie7 | Refrigerator & Freezer Repair | 1 | 08-09-2007 05:10 PM |
