Discuss
starts/stops
 in
Dryer Repair
push button it starts, release button it stops. as long as button is depressed, unit will run but no heat,
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » starts/stops
  #1 (permalink)
Old 10-12-2007, 01:35 PM
johnlferg2 johnlferg2 is offline
Junior Member
johnlferg2 is on a distinguished road
Default starts/stops
Model Number: 70 series   Brand: Kenmore   Age: 5 - 10 years
as long as button is depressed, unit will run but no heat, and timers do not advance
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-14-2007, 04:45 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If you have a simple start switch without a relay, you have a bad start switch on the motor. I would pull dryer apart and stick 115 volts to pins 4&5 of the motor to confirm.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Starts to pump during wash then shuts down, starts, stops real quidk sirgalagit Dishwasher Repair 1 10-03-2007 09:23 PM
front load washer starts and stops immediately sunshine Washer Repair 0 10-01-2007 07:16 AM
Dryer starts then stops Redwings19 Dryer Repair 0 09-20-2007 10:09 AM
Dryer makes rumbling sound when starts Scottnvegas Dryer Repair 3 08-12-2007 09:00 PM
Oven temp guage starts at 315 degrees RBS Oven Repair (including Ranges and Cooktops) 0 08-10-2007 09:28 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
