herfman10
#1 Posted : Monday, January 17, 2011 5:06:35 PM(UTC)
herfman10
I have a Whirlpool Cabrio dryer that is taking 2-3 cycles to dry clothes. Element is fairly hot to the touch, but curious if it is failing and just not getting hot enough. Any thoughts?
#2 Posted : Tuesday, January 18, 2011 3:35:37 AM(UTC)
Replacement parts for WHIRLPOOL WED6400SW1 29`` ELECTRIC DRYER | AppliancePartsPros.com
The most common cause of this is a partially plugged or malfunctioning vent system.
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
