Ok I was suppose to be changing the drum belt on this when I say a loose yellow wire. It looked like it belonged attached to the motor so i attached and turned on the dryer. wrong move. sparks came out and now the dryer is not working at all. How can I tell if I blew the fuse, timer or motor? Is there a fuse on this model? I have been told yes and no so I do not know which is correct.
Thanks for your help
Linda
