| » Roper Dryer wont turn on |
Model Number: RED4340SQ1 Brand: Roper Age: 1 - 5 years
I've already checked the door switch, start switch, thermal switch, and what I believe is the motor switch. I believe the motor is the culprit, just want to make sure that it is the motor before I go replacing it. How do I go about testing the motor...or even getting to it for that matter? Is it possible that I can ohm the wires to and from to save the hassle of tearing the dryer completely apart?
Here is the wiring diagram, see the attachment.
Toy could try the following. Unplug the unit. Set the timer to OFF to ensure BK/BU timer contacts are open. Set your meter to it's most sensitive scale. Measure from BU on the timer to the W or W-r on the push to start switch (left hand side on the wiringb diagram. Should be 1 to 2 ohms.
__________________
Turns out to be the thermal switch. I didn't get anything when I tested the entire flow. It's getting caught up at the thermal fuse. But the test from the motor side of the thermal fuse back up to the start switch is good and from the other side of the thermal fuse up to the timer is good as well. So, hopefully, this is a $10 fix. Thanks for your time.
| Display Modes | |
| Roper dryer wont start | cassandrea01 | Dryer Repair | 2 | 12-29-2010 06:38 PM |
| Need help with Roper dryer. Switch clicks but won't turn on | karenm | Dryer Repair | 1 | 05-10-2010 03:17 AM |
| Roper dryer wont heat | JAM25 | Dryer Repair | 13 | 02-02-2010 07:51 PM |
| Roper dryer won't turn on | TominPA | Dryer Repair | 6 | 06-21-2009 05:48 AM |
| roper dryer wont turn on | chsyer | Dryer Repair | 3 | 10-19-2008 10:09 AM |
