| » Maytag dryier help/info needed |
Model Number: MDG5500AWW Brand: Maytag Age: 1 - 5 years
Here is what's going on...
Dryier starts, igniter lites, gas valve comes on and lites, runs 20-30 sec. and then cuts out on high limit. (220-40 F high temp limit opens). Took apart, cleaned, cut some of the air down until good blue flame and now it will run for a min or two and then cycles off the valve and then comes back on. Checked out gas pressure when the valve opens and ignites and it is about 2-2.5" in W.C. So, here are my questions: Is it normal for the unit to cycle the burner on and off? What is the normal/typical discharge temp out of the back of the dryier? What is a normal/typical temp inside the dryier? What else should I be checking for? Ads By Google Related Models |
Yes, it is normal for a dryer heating element (gas or electric) to cycle "on" and "off".
Is it anything wrong with the dryer now? Why do you need to check anything? Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| elec dryier starts then stops | RADIOGEEK97 | Dryer Repair | 8 | 09-07-2010 10:08 PM |
| Help needed Maytag Dryer | girlysmiles | Dryer Repair | 1 | 10-12-2009 08:37 PM |
| MayTag Washer Help Needed | actionguns | Washer Repair | 1 | 06-16-2009 06:41 PM |
| Door won't open - latch info needed | lakehouse | Microwave Repair | 6 | 02-11-2009 05:41 PM |
| Maytag dryer part info needed | bryteblu | Dryer Repair | 0 | 01-25-2008 11:28 AM |
