| » Light comes on, timer clicks, drum does not turn. |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: 96589210 65892 Brand: Kenmore Age: 5 - 10 years
I have a Kenmore Heavy Duty 80 Series Dryer that will not work for me suddenly. For the past year or two the start button has not worked. This was never a problem, once the timer was set & the door was closed it would start automatically. Now the dryer will not start at all. When I open the door the light comes on; when the timer is set and the door is closed, all I can hear is the timer "clicking" but the drum does not turn. I have opened up the control panel, Removed the top & the kick panel. I cannot see anything that looks to be "fried". Any information would be greatly appreciated.
You will need a meter to check things. Make sure your start switch is shorted, then check for 230 volts into the dryer, then check your thermal fuse, a white item on the back blower housing.
__________________
| Display Modes | |
| not turning of the drum | scott glynn | Washer Repair | 1 | 10-12-2007 10:51 AM |
| Drum won't turn, nothing stuck..... | tbrunson | Washer Repair | 1 | 10-10-2007 02:47 AM |
| Dryer drum doesnt turn | eric1025 | Dryer Repair | 3 | 10-07-2007 02:47 AM |
| Dryer drum won't turn | tlathan | Dryer Repair | 1 | 08-15-2007 04:12 PM |
| Timer will not turn off | rb8941 | Dryer Repair | 1 | 08-01-2007 10:11 PM |
