Discuss
dryer shows code F-22
 in
Dryer Repair
what does F22 mean? runs for one minute & shuts off.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer shows code F-22
  #1 (permalink)
Old 01-13-2011, 03:44 PM
Junior Member
greatergraces@yahoo.com is on a distinguished road
Default dryer shows code F-22
Brand: Whirlpool   Age: 1 - 5 years
  #2 (permalink)
Old 01-13-2011, 04:21 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Greatergraces,
I can't find an F22 code for a WP dryer,
Are you sure about that fail code ?
If you could get us a proper model number, we'd be more helpful, and can assist you better.
Thanks,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 01-13-2011, 05:38 PM
Junior Member
Unhappy
) yes does flash F-22 read at the bottem of page [ quote=Joe / APP Team;332503]Greatergraces,
Thanks,
[/quote Model # is WED6200SW1 Dryer does come on using any temperature settings but shuts off after 1 minute then Flashes F-22 .On temperature setting air only dryer does operate through time setting but the temperature stays extremely hot. thank you for your help we appreciate.
  #4 (permalink)
Old 01-14-2011, 06:59 AM
Senior Expert
Default
[quote=greatergraces@yahoo.com;332532]
Quote:
Originally Posted by Joe / APP Team View Post
Greatergraces,
Thanks,
Greatgraces,
Thanks,
Of course you're correct, your dryer does have a F22 code.
That code indicates that the Exhaust thermistor resistance is out of specified range,
You added something,
On timed dry, air dry setting(no heat), the dryer gets extremely hot ?
Is that correct ?
I was hoping you just had a clogged vent or bad thermistor, but with that information, we've got another problem, shorted element, shorted wires, bad control board,
You should get a multi meter, so you can check resistances and circuits, or
disconnect the exhaust venting from the back of the dryer and run it on air dry, then a heat cycle and varify, that there's heat in the air dry(no heat) setting.
We'll keep an eye out for your response,
Good Luck,
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 01-18-2011, 07:13 AM
Junior Member
Default
HELP yes said F-22 read at the bootom of page
Greatergraces,
Thanks,
  #6 (permalink)
Old 01-18-2011, 07:16 AM
Junior Member
Default
greatergrace already have dissconnected exhaust & air dryer is very hot,we already put part that we order on .
  #7 (permalink)
Old 01-18-2011, 09:58 AM
Senior Expert
Default
Greatergraces,
So much for the easy stuff,
I was not aware you replaced a part, what part did you replace ?
Now,
You'll need to access the rear of the dryer, remove the back panel,
1. Unplug dryer or disconnect power.
2. Remove the rear panel
3. To remove the thermal cutoff (TCO)
a) Remove the two wires from the TCO
terminals.
b) Remove the hex-head screw, unhook
the end of the bracket, and remove
the TCO.
4. To remove the heater and inlet thermistor/
high-limit thermostat
a) Lift the locking tab and remove the
2-wire connector from the inlet thermistor.
b) Remove the wire connector from the
high-limit thermostat terminal.
c) Remove the two wire connectors from
the heater terminal block.
Check for a resistance reading from each terminal to the flue box/housing. any resistance would indicate a shorted element and you'd need to replace the heater assembly.
d) Remove the two hex-head screws from
the heater assembly and remove the
assembly.
e) Using a flat-blade screwdriver, pry the
inlet thermistor terminal off the heater
terminal, and remove the thermistor from
the assembly.
Part number: AP3094254
The next step would be,
to access the main control board,
2. Turn off gas supply to dryer.
3. Remove the two mounting screws from
the rear of the console.
4. Lift the console off the cabinet and position
it off to the side.
To remove the machine control:
a) Disconnect the machine control board
connectors at P8, P9, P13, and P14,
then pull the red and black wires off the
heater relay terminals. NOTE: On dual
element models, also disconnect the
violet and black wires from the second
Once you've removed the wires from the heater relay,
with a multi meter, there should be no resistance across the two terminals on the relay, if there is, the relay is stuck closed, and causing the element to be on in all settings, and you'll need a machine control board.
Part number: AP4359310
I'm pretty sure you'll find your problem in one of these areas,
or the wiring to one or the other.
Good Luck,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave Shows F-9 error code divrcal1 Microwave Repair 2 01-26-2010 01:53 PM
Dryer shows error code e1 jamm Dryer Repair 0 08-27-2009 08:09 PM
Error code shows up after using self clean feature welch5 Oven Repair (including Ranges and Cooktops) 1 11-11-2008 07:49 PM
Whirlpool microwave shows F2 code and stopped working Josh0621 Microwave Repair 3 10-16-2008 07:45 PM
Oven does not work after self clean. Shows fault code F1 Nicolez123 Oven Repair (including Ranges and Cooktops) 3 02-11-2008 11:06 AM
