mikmat63
#1 Posted : Thursday, January 13, 2011 1:53:41 PM(UTC)
mikmat63
stacked unit, not heating well, lint trap/line relatively clean. thermostat?
thanks
Troglodad
#2 Posted : Monday, January 24, 2011 11:16:42 AM(UTC)
Troglodad
My Kenmore417.99680210 has completely stopped working. I've gone through three thermal fuses.
Mine was barely drying as well the past year. In the process of trying to get this problem fixed, I did repalce the exhaust vent and shop vac the inside of the dryer out. Removed a TON of lint.
Now the problem is it dries TOO good. I had five towels dry in two half-hour timed cycles on LOW. I suspect it's a bad thermostat, but won't know for sure until I replace it.
I have a running thread on this over at appliantology.org, but will also follow your progress.
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
Still not heating (Dryer Repair)
by artinmartin 10/23/2023 2:36:57 PM(UTC)
new heating element, but still not heating (Dishwasher Repair)
by ScotofBV 7/13/2023 5:47:30 PM(UTC)
How to diagnose Thermador gas oven PG366BS not heating? (Oven Repair (including Ranges and Cooktops))
by Guest 4/12/2023 12:28:01 PM(UTC)
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Kenmore Elite HE3 not heating and drum not spinning (Dryer Repair)
by Guest 12/23/2022 11:32:17 AM(UTC)
Thermadore PRG304GH oven not heating (Oven Repair (including Ranges and Cooktops))
by Guest 12/15/2022 6:58:50 AM(UTC)
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
by Guest 10/14/2022 12:50:23 PM(UTC)
GE Microwave Louder and Not Heating PEB7226SF2SS (Microwave Repair)
by Guest 7/24/2022 9:39:41 AM(UTC)
Samsung Gas Dryer Model DV42H5000GW/A3 not heating (Dryer Repair)
by mikeb22 6/1/2022 9:47:03 AM(UTC)
Whirlpool double wall oven lower not heating (Oven Repair (including Ranges and Cooktops))
by mid 5/23/2022 12:46:49 PM(UTC)
Samsung DV395ETPASU/A1 not heating (Dryer Repair)
by Guest 3/5/2022 5:01:06 PM(UTC)
Bosch washer not heating (Washer Repair)
by Guest 2/6/2022 2:10:46 PM(UTC)
Bottom oven not heating (Oven Repair (including Ranges and Cooktops))
by Castelle 1/21/2022 6:17:26 PM(UTC)
Samsung dryer DV42H5200 still not heating after replacing all components (Dryer Repair)
by Guest 1/9/2022 11:26:52 AM(UTC)
