lonnietutsch
#1 Posted : Thursday, January 13, 2011 9:22:58 AM(UTC)
lonnietutsch
My dryer will not shut off or advance in any of three available cycles. It does shut off when I open the door. Clother are being dried fine in all cycles.
#2 Posted : Thursday, January 13, 2011 1:55:26 PM(UTC)
Open the control panel and check the resistor connected to the timer motor. Normally it suppose to be about 5000 Ohms. Post the results.
You missed the end of the model number. Verify and repost it.
lonnietutsch
#3 Posted : Saturday, January 15, 2011 12:37:21 PM(UTC)
lonnietutsch
Gene,
Thanks for the input. I called one of your other depts for some help on another issue and they asked me what the problem was......They told me I needed a timer and sent one out....got it today. Haven't opened the box yet so I confused on which route to take.
If I go your route(since your the tech that makes sense) what tool do I need to check the OHMS?
Thank you,
LT
#4 Posted : Monday, January 17, 2011 8:23:07 PM(UTC)
You can use any ohmmeter.
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest Today at 12:21:03 PM(UTC)
DLEX5780WE lg dryer shutting off before the clothes are dry. (Dryer Repair)
by LMA 4/13/2024 11:00:21 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
grease for rear dryer bearing (Dryer Repair)
by bronn033 3/30/2024 12:57:30 PM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
Replacement dryer motor W11364931 (Dryer Repair)
by Guest 3/23/2024 8:47:41 AM(UTC)
Maytag electirc dryer model LDE9334ACM (Dryer Repair)
by Guest 3/22/2024 6:07:19 PM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
