The drum spins freely when the tension spring on the idler pulley is released. With the tension spring in place the drum is difficult to turn and emits a grinding sound. This dryer dates back to 1973 and I suspect the bearing in the blower housing is NG. If you think this is the problem and I was able to locate a new blower housing with bearing (Part #WPLY302815) how difficult is it to replace. At this point I have removed the control panel and cabinet. Your help is greatly appreciated.
