Discuss
how to test flame sensor
 in
Dryer Repair
how do you test the flame sensor?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » how to test flame sensor
  #1 (permalink)
Old 12-01-2008, 04:47 PM
Junior Member
lordrandy is on a distinguished road
Default how to test flame sensor
Brand: Whirlpool   Age: More than 10 years
  #2 (permalink)
Old 12-01-2008, 07:09 PM
Junior Member
richierich2580 is on a distinguished road
Default
you check the micro-amps with a meter. if it is weak you can clean it with sand paper that usually does the trick!
  #3 (permalink)
Old 12-02-2008, 07:02 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Check it with an ohm meter, should be initially shorted.
__________________
  #4 (permalink)
Old 12-03-2008, 05:12 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
If not totally confused, take the 2 wires off, and put the terminal ends together, and put a little tape around it, and then plug the dryer in, and see if it works. If it does, DON NOT RUN the dryer like that. We do not want to burn down the house. This is to check only. Tom ********************************************
  #5 (permalink)
Old 12-03-2008, 06:33 AM
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default
If power cannot flow through the flame switch then the ignitor will not glow.
But why don't the gas come out as well? All are on the same circuit. The answer is: The ignitor hogs all of the power. So the job of the flame switch is kill the power to the ignitor when it gets glowing cherry red so that power can energize the coils and open the gas gates. As soon as the gas hits the hot Ignitor it catches fire like a blow torch and remains on until all the power is killed to that gas assembly by the controling thermostat mounted on the blower housing. So the Flame sensor needs to have continuity while cool and no continuity while hot.
  #6 (permalink)
Old 12-03-2008, 08:05 AM
Senior Expert
APP Volunteer
Default
Very good, I learned something.
__________________
  #7 (permalink)
Old 07-14-2010, 03:23 AM
Junior Member
rhankins is on a distinguished road
Default
I have a similar issue with the igniter not igniting and the burner not lighting. I tested the cold resistance of my igniter, and it indicates 90 ohms, which appears to be good. I then tested the cold resistance of my flame sensor, and it tested open. I connected the leads of the flame sensor together, and the igniter glows, but the burner does not light. Any idea what my issue might be?
Thanks,
-Ryan
  #8 (permalink)
Old 07-14-2010, 03:42 AM
Senior Expert
APP Volunteer
Default
Your igniter is worn out, resistance too high, for a flat igniter, I believe it should draw more than 3 amps to cause the gas valve to open.
__________________
  #9 (permalink)
Old 07-14-2010, 10:52 PM
Senior Expert
APP Volunteer
Default
Touch the two leads together till the ignitor glow red hot then seperate the wires. The gas should come out. If not then the solenoids are bad.279834.jpg
  #10 (permalink)
Old 07-15-2010, 01:17 AM
Senior Expert
APP Volunteer
Default
You are correct, I missed the cold open flame sensor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
flame sensor Bob P Dryer Repair 0 01-19-2010 03:59 PM
flame sensor lnarvaez Oven Repair (including Ranges and Cooktops) 0 09-12-2009 12:15 PM
Flame sensor redrwut Dryer Repair 4 02-21-2009 03:21 PM
flame sensor sarrah76 Dryer Repair 1 01-10-2009 05:38 AM
flame sensor sarrah76 Dryer Repair 1 01-10-2009 05:37 AM
