Discuss
Wire burning/melting connected to heating element
 in
Dryer Repair
Hi- The wire that is connected to the stud on the heating element will burn/melt and eventually break off
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Wire burning/melting connected to heating element
  #1 (permalink)
Old 12-01-2008, 12:27 PM
tokolowicz tokolowicz is offline
Junior Member
tokolowicz is on a distinguished road
Default Wire burning/melting connected to heating element
Model Number: SDE515DAYW   Brand: Maytag   Age: 1 - 5 years
Hi-
The wire that is connected to the stud on the heating element will burn/melt and eventually break off from the stud, which causes the dryer not to have any heat.
I cut back the burnt wire, put a new slip-connector on, ensured it was a tight fit on the stuf, and the same problem happened after about a month or so. I know there are many wires that connect to various parts on the heating element, but this is the black wire that terminates on a stud that is connected directly to the heating coils. The two gray wires connected to the thermal fuse and the purple wire connected to the thermostat is fine.
I did not check continuity of the heating element parts at this time because the heating element works fine when the wire is connected. Problem is that the wire gets too hot and eventually burns to a charcoal, and this is not good for many reasons, most importantly being a fire hazard.
What could be causing the wire to get too hot now after three years of use without this issue? Do I need to replace the heating element? Any other troubleshooting tips and/or past experience with a similar issue would be much appreciated. I need to isolate the bad component/s and get this dryer working again!
Thanks in advance for your help.
/Todd
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-02-2008, 04:56 AM
denman denman is offline
Senior Expert
APP Volunteer
denman is on a distinguished road
Default
Did you clean the heater's stud before putting on the new connection? Sometimes they can get pitted or develop a coating usually light gray or tan.
Also was the slip connector you used rated for high temp?
My guess would be that the heater coil itself has a poor connection to the plug. This resistance is acting like heater, the stud gets hot and burns back you insulation.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Problem reconnecting wire to heat element Loriabrass Dishwasher Repair 1 05-28-2008 03:01 PM
Burnt Wire to Heating Element Trigger2 Dryer Repair 0 05-21-2008 12:10 PM
unable to find element wire homebuilder0481 Oven Repair (including Ranges and Cooktops) 1 01-31-2008 04:45 PM
Maytag CRE9400CCE Bake element LEAD wire COLOTOM Oven Repair (including Ranges and Cooktops) 1 12-24-2007 02:25 PM
Infinite Wire Switch Dual Element leighr3 Oven Repair (including Ranges and Cooktops) 1 12-11-2007 02:04 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
