Discuss
Whirlpool Thin Twin dryer thermal fuse blown
 in
Dryer Repair
Whirlpool Heavy Duty Thin Twin has worked fine for years. Then it stopped heating. I've checked continuity of the following
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Thin Twin dryer thermal fuse blown
  #1 (permalink)
Old 01-11-2011, 10:57 AM
Junior Member
pdinnen is on a distinguished road
Default Whirlpool Thin Twin dryer thermal fuse blown
Brand: Whirlpool   Age: 5 - 10 years
Whirlpool Heavy Duty Thin Twin has worked fine for years. Then it stopped heating. I've checked continuity of the following parts using an ohmmeter:
3404154 fixed thermostat - closed
3399848 thermal cut off fuse - closed
3399849 thermal fuse - open
There's a label inside the machine that tells me that a blown thermal fuse also requires the replacement of the "operating thermostat/thermistor". But I am having trouble tracking down that part number. Any suggestions?
Also any step by step suggestions for diagnosing the original cause of the problem?
  #2 (permalink)
Old 01-12-2011, 06:25 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Need a model number.
Model Number Locator
If the thermal fuse is the one on the blower then I do not know why they are recommending replacing the operating thermostat.
The most common cause of this fuse blowing is a dirty or malfunctioning vent system.
__________________
  #3 (permalink)
Old 01-12-2011, 07:04 AM
Junior Member
Default Found the model number
The model number is YLTE5243DQ1
  #4 (permalink)
Old 01-12-2011, 07:34 AM
Senior Expert
APP Volunteer
Default
Cannot find DQ1 so the following is the closest Icould get DQ2
Replacement parts for WHIRLPOOL YLTE5243DQ2 WASHER/DRYER LAUNDRY SYSTEM | AppliancePartsPros.com
Here is a wiring diagram,see the attachment.
Here is your thermal fuse and the operating thermostat
Part number: AP2947182
Part number: AP2975271
Click on the picture for more info.
They recommend replacing both because they feel that the thermostat should have opened and shut off the heater before the fuse blew,
For the cost of the thermostat I would also replace it.
Note: What wires attach where as it is a 4 connector thermostat. 2 for the contacts and 2 for the internal heater so it is important that you do not get them mixed up.
Clean and check your vent system.
Also you should check the heating element.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 13 to 20 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal fuse blows.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool thin twin dryer belt instulation Dryermang Dryer Repair 2 07-01-2011 09:03 PM
Whirlpool thin twin stackable washer and dryer numisman1@yahoo.com Dryer Repair 2 12-14-2009 08:21 PM
thermal fuse blown, gas dryer crazyman Dryer Repair 1 09-07-2008 02:28 PM
Whirlpool Thin Twin dryer will not heat bolingmike Dryer Repair 0 07-29-2008 01:42 PM
Whirlpool Thermal Fuse Blown gerardjuarez Dryer Repair 1 05-12-2008 06:58 PM
