Register | FAQ's | New Posts | Today's Posts | Extras |
» Gas dryer will not heat |
![]() Model Number: 11072212100 Brand: Kenmore Age: 5 - 10 years
![]() My gas dryer will not heat up but the drum will turn. no lint and the vent is clear. Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Take a look and see if the glow coil comes on. If not, take the back off the dryer, and you will see a part about an inch and a half long, by a half inch wide, and it is white in color. That is the thermal fuse. Make sure the dryer is unplugged, and take the 2 wires off the thermal fuse, and put the terminal ends together, and put a little tape on it, so it does not hit metal, and then see if it works. If it does, DO NOT RUN the dryer that way. That thermal fuse is the only thing stopping that dryer from burning down the house. If it does not work it will either be the ignitor or the flame sensor. Tom ********************************************
![]() Glad to help both of you. Tom ********************************************
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. | NEAL AMES | Dryer Repair | 1 | 01-02-2009 06:40 PM |
Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 03:50 PM |
