Discuss
dryer not heating
 in
Dryer Repair
Dryer does not heat up Ads By Google
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer not heating
  #1 (permalink)
Old 01-09-2011, 07:40 PM
Junior Member
rvalentin is on a distinguished road
Default dryer not heating
Brand: Roper   Age: 5 - 10 years
Ads By Google
  #2 (permalink)
Old 01-10-2011, 03:23 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
A model number may help others help you.
I am assuming that this is an electric dryer.
The first thing to check is the power. On most units the motor, light and timer run on 120 volts but the heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Help: Dryer works fine and turns on fine but will stop heating after 1min missjsmith11 Dryer Repair 1 08-21-2010 05:59 AM
dryer not heating doghouse3 Dryer Repair 1 09-23-2009 06:11 AM
Dryer not heating TomCassisa Dryer Repair 1 09-07-2009 07:38 AM
Dryer not heating TomCassisa Dryer Repair 0 09-05-2009 01:43 PM
Gas Dryer Not Heating lmb1063 Dryer Repair 0 04-25-2009 12:29 PM
