Discuss
Need Kenmore 110.87980100 Dryer Diagnosis Help, Tried reasonable tests
 in
Dryer Repair
My Kenmore 110.87980100 dryer (Serial # MA3305936) has gone from taking a very long time to dry, to not completely
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Need Kenmore 110.87980100 Dryer Diagnosis Help, Tried reasonable tests
  #1 (permalink)
Old 01-09-2011, 11:50 AM
Junior Member
MikeInMA is on a distinguished road
Question Need Kenmore 110.87980100 Dryer Diagnosis Help, Tried reasonable tests
Model Number: 110.87980100   Brand: Kenmore   Age: More than 10 years
My Kenmore 110.87980100 dryer (Serial # MA3305936) has gone from taking a very long time to dry, to not completely drying a load of towels at all. I'm a generally handy homeowner, having fixed mechanically related problems with the dryer (belt/pulley) and washer before, but I am stumped how to proceed from here. I have tried to diagnosis the problem myself, using a repair book and internet sources, but I need help.
First, I observed the burner operation, with the dryer empty, and found that the ignitor glowed, the gas valves opened, a flame burned (mostly blue); it only burned for 44 seconds before it shut off, remained off for about 1.5-2 minutes, then burned again for only 22 seconds. This is not normal, this is short, right??
Based upon this, I followed the diagnostics reccomended in the book for FLAME STARTS (GAS VALVE OPENS) BUT KICKS OFF QUICKLY (SHORT-CYCLES, LOW HEAT):
1) Airflow: was of course the first stop. I feel I tackled this a couple days before, when I cleaned the lint trap, lint chute, exhaust duct, and exhaust vent thoroughly, as I have a number of times before, with hands and vacuum. This time, I even bought a brush kit, and used those in the lint chute and exhaust duct. A lot of lint came out. The exhaust situation is not ideal, but has worked well enough for 20 years. Flexible metal duct, must go up vertically about 8-9 feet, past the basement concrete foundation, with two 90 degree bends, one where it meets the dryer, the other at the top where it meets the louvered exterior vent.
2) Check for defective flame sensor: checked for continuity (using digital multimeter), was good (0).
3) Check thermostats:
a) 150 degree thermostat on blower housing (lint chute) - continuity was good
b) 250 degree thermostat on heater box - continuity was good
c) Thermostat Heater (surrounding the 150 degree thermostat on blower housing) - continuity with multimeter set on audible was 1.54, with multimeter set on 200 and 2K was 1. ??Is this correct??
d) Thermal Fuse - continuity was good, of course
Can a thermostat be bad even if it passes the continuity test when it is cold??
I did not check the coils, as this was not in the recommended diagnostics for this problem in the book, and I know they are allowing gas through. Should I check them??
The other thing I did, and I realize that it may indicate bad airflow, but again, this unit has run well enough for 20 years with this venting setup, is I ran the empty machine after detaching the external vent; the burner burned for over 5 minutes on its first cycle... I stopped the dryer without letting the burner cycle off at that point.
How long is the "proper" amount of time for the burner to run?
Please answer my questions, and recommend a course of action... I'd truly appreciate some quality help.
Thanks, Mike
Ads By Google
Related Models
Kenmore 110.92490100  GAS DRYER
Kenmore 110.92822100  GAS DRYER
Kenmore 110.92822101  GAS DRYER
Kenmore 110.92822102  GAS DRYER
Kenmore 110.92824100  GAS DRYER
Kenmore 110.92824101  GAS DRYER
Kenmore 110.92824102  GAS DRYER
Kenmore 110.92826100  GAS DRYER
Kenmore 110.92826101  GAS DRYER
Kenmore 110.92826102  GAS DRYER
Kenmore 110.92832100  DRYER
Kenmore 110.92834100  DRYER
Kenmore 110.92836100  DRYER
Kenmore 110.94832200  GAS DRYER
Kenmore 110.94832201  GAS DRYER
Kenmore 110.94834200  GAS DRYER
Kenmore 110.94834201  GAS DRYER
Kenmore 110.94836200  GAS DRYER
Kenmore 110.94836201  GAS DRYER
Kenmore 110.96060100  ELECTRIC DRYER
Kenmore 110.96091100  ELECTRIC DRYER
Kenmore 110.96091300  ELECTRIC DRYER
Kenmore 110.96091700  ELECTRIC DRYER
Kenmore 110.96091800  ELECTRIC DRYER
Kenmore 110.96093100  ELECTRIC DRYER
Kenmore 110.96093300  ELECTRIC DRYER
Kenmore 110.96093500  ELECTRIC DRYER
Kenmore 110.96093700  ELECTRIC DRYER
Kenmore 110.96093800  ELECTRIC DRYER
Kenmore 110.96094100  ELECTRIC DRYER
Kenmore 110.96094300  ELECTRIC DRYER
Kenmore 110.96094500  ELECTRIC DRYER
Kenmore 110.96094700  ELECTRIC DRYER
Kenmore 110.96094800  ELECTRIC DRYER
Kenmore 110.96110100  ELECTRIC DRYER
Kenmore 110.96121100  ELECTRIC DRYER
Kenmore 110.96195100  ELECTRIC DRYER
Kenmore 110.96195110  DRYER FEATURE SHEET
Kenmore 110.96407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.97502120  GAS DRYER-COMMERCIAL
Kenmore 110.97502820  GAS DRYER-COMMERCIAL
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
Kenmore 11022032101 WASHER
Kenmore 11022032102 AUTOMATIC WASHER
Kenmore 11022036100 WASHER
Kenmore 11022036101 WASHER
Kenmore 11022036102 AUTOMATIC WASHER
Kenmore 11022042100 WASHER
  #2 (permalink)
Old 01-09-2011, 02:38 PM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
You are still getting poor/ turbulent air flow. An air flow meter would confirm this. The fact that it worked "normally" with the ducting off confirms this.
One solution is to buy a 4 inch brush with 15 foot extensions called "Lint eater" around $39 plus shipping.
Another solution is to use a shop vac (higher hp the better) and blow the lint out. Lots of times the lint will bunch up and cause turbulence, the shop vac might just clear it out.
__________________
  #3 (permalink)
Old 01-09-2011, 02:40 PM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
I have seen people use a leaf blower from the inside of the house, and blow it. Of the hook option, but it works. Tom ********************************************
  #4 (permalink)
Old 01-09-2011, 04:18 PM
Junior Member
Default
I appreciate both your responses.
as stated in (1), I did buy and use a brush kit, in fact, it was the LintEater kit.
I know that it could be an airflow problem, but again, it has run well enough for 20 years with this venting setup. So if airflow is a factor, it seems like something else must have happened to cause my current problem.
there are 4 other questions within my first detailed posting, that are very important things that I cannot answer... can anybody answer those??
I'd appreciate any help with that.
  #5 (permalink)
Old 01-10-2011, 01:13 AM
Senior Expert
APP Volunteer
Default
Some of your questions can't be answered. Your burner will run as a function of airflow, poor airflow will open the thermostats sooner than "normal".
I missed the fact that you have flexible ducting in the house. This stuff is not per code and will clog easily. You might try using the lint eater with a power drill to get all the lint out. Any partial restriction will cause turbulence. Hold a sock up to the dryer vent, then compare it's rise outside when the ducting is connected, will demo the extent of your venting problem.
__________________
  #6 (permalink)
Old 01-10-2011, 08:41 AM
Junior Member
Default
Quote:
Originally Posted by richappy View Post
... Some of your questions can't be answered. Your burner will run as a function of airflow, poor airflow will open the thermostats sooner than "normal".
... have flexible ducting in the house. This stuff is not per code and will clog easily.
... Hold a sock up to the dryer vent, then compare it's rise outside when the ducting is connected, will demo the extent of your venting problem.
1) Can this question, from my initial write-up, be answered:
2) the ducting is the semi-rigid metal kind, except at the 2 elbows, which are rigid. Is that per code? will that clog easily?
I am probably going to change it to as much rigid ducting as I can right now.
3) the sock is a good simple tool, better than my hand, thank you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
diagnosis help for a whirlpool ChicagoD Dishwasher Repair 2 04-06-2009 06:12 AM
