craigapple
#1 Posted : Saturday, January 8, 2011 9:27:06 AM(UTC)
craigapple
I have 240 v at the terminal block. The heating coil is not grounded & shows continuity. The thermal limiter, control thermostat & high limit thermostat all have continuity & 3-4 ohms resistance.
I have a 20+ yr. old Time-Life major appliance repair manual & followed the testing procedures in it. Obviously it is outdated on some things. I tried to test the centrifugal switch, but the manual talked about checking continuity & resistance with the button pushed in and then with it out - couldn't figure out what they were talking about - there is no button on mine. I took it apart and all the connections look clean, so I don't think it could be the problem.
The only thing I really found wrong is that the manual said the timer motor should test at 2-3,000 ohms. With my digital multimeter set to 200 ohm range, the display didn't change from the number 1. Could the timer motor even affect the heat?
Thanks for your help!
Craig
craigapple
#2 Posted : Saturday, January 8, 2011 2:14:58 PM(UTC)
craigapple
Never mind - it ended up being a broken heating coil. It's fixed.
Dryer will not heat (Dryer Repair)
by MByram 4/22/2018 8:36:12 PM(UTC)
Dryer Will Not Heat (Dryer Repair)
by coreyhall 3/6/2017 10:18:48 AM(UTC)
Dryer will not heat or turn off (Dryer Repair)
by jesus freak 1/17/2016 2:25:22 PM(UTC)
by rwebb 12/4/2015 9:44:48 AM(UTC)
Dryer will not heat and will not shut off (Dryer Repair)
by HMH1983 9/23/2015 6:44:16 PM(UTC)
Default Dryer will not heat, timer does not work (Dryer Repair)
by gotcoffee82 3/1/2015 7:37:21 PM(UTC)
Dryer will not heat up (Dryer Repair)
by kpholler 12/2/2014 3:42:57 PM(UTC)
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
Kenmore Dryer Will Not Heat After Replacing Everything (Dryer Repair)
by jlewis57 10/1/2014 12:28:50 PM(UTC)
Dryer will not heat and timer will not advance (Dryer Repair)
by MNJames 9/15/2014 2:46:05 PM(UTC)
Dryer Will Not Heat, But All Parts Test OK (Dryer Repair)
by kamera 9/6/2014 9:33:05 AM(UTC)
Roper dryer will not heat (new parts installed too) (Dryer Repair)
by xenomorphlv426 2/1/2014 8:49:03 AM(UTC)
GE harmony profile gas dryer will not heat (Dryer Repair)
by Thespiderman20 9/10/2013 5:44:45 PM(UTC)
Dryer will not heat. (Dryer Repair)
by modelshop8624 7/4/2013 1:24:12 PM(UTC)
Kenmore Dryer will not heat but the drum runs (Dryer Repair)
by asirota1 3/25/2013 8:33:52 AM(UTC)
