brandi1109
#1 Posted : Wednesday, January 5, 2011 7:24:59 AM(UTC)
brandi1109
My electric dryer turns on but take forever to dry clothes. The heating element in the dryer tub gets warm but not hot. I cleaned the dryer vent out. Anyone have any suggestions
#2 Posted : Thursday, January 6, 2011 1:53:53 AM(UTC)
Section replacement parts for WHIRLPOOL LEB6400KQ1 | AppliancePartsPros.com
I would start by checking the heating element.
Could be it is grounded.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on low.
