| » gas dryer |
Model Number: LGR8857EQ1 Brand: Whirlpool Age: More than 10 years
Dryer Is Not Getting Hot Only Cold Air Being Exhausted Through Vent. Checked Vent And Is Not Clogged. Please Help
Quote:
Jotto, This should be a gas dryer(heat source). Have you removed the 1x1 plastic cover in the front panel and observed the ignition procedure ? You do have gas supplied to the unit ? When you remove the inspection cover, and look inside, you should see: An orange glow,from the glowbar igniter, In a few seconds, you should hear a click, and the glow bar igniter should start to fade. At the same time the igniter starts to fade, you should be able to see the burner flame ignite, *** Make sure a temperature selection is made and the timer dial is in a heat mode ( I usually set the dial on timed dry, at the 30 minute mark).*** Let us know what you observe, and we can get you on the correct path to repair your dryer. Thanks,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Kenmore Elite Washer and Dryer. Dryer model # 11060096991 | fburr4054 | Dryer Repair | 1 | 11-21-2011 06:12 AM |
| Kenmore Dryer - Timer not moving with No heat and dryer does not shut off | poslow | Dryer Repair | 2 | 11-21-2010 10:10 PM |
| Electrolux laundry center (stack washer/dryer) dryer won't start | maddy | Dryer Repair | 0 | 09-21-2010 05:23 PM |
| Dryer will not heat and now smell gas when I open the dryer door | oheguy | Dryer Repair | 1 | 03-10-2009 12:59 PM |
| Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. | NEAL AMES | Dryer Repair | 1 | 01-02-2009 06:40 PM |
